After having fixed a dry solder joint in my AFM tonight(Most likely from the heat I'm about to talk about) I noted that the engine bay gets damn hot and stays hot for a long time (Series II R33 GTR). With this in mind I'm wondering if anyone has endevoured to vent the bonnet or purchase a vented bonnet with the aim of reducing engine bay temps and hopefully prolong component life. I'm not looking for huge rice vents, just options on something practical.
What are peopls thoughts on this idea, do you run the risk of allowing rain/debris/dust/dirt etc into the engine bay in larger than normal amounts, is there a real temp drop as a result, what have people done if they've pursued this idea (pics would be great too).
Thanks all
https://www.sau.com.au/forums/topic/151325-bonnet-venting/
  • Replies 68
I had a Carbon fibre vented bonnet and that kep my temps down and also had a inlet over hte air filter. When i went to a standard bonnet i felt the car was not as responsive prob due to no air intake vent. i aslo found on hot days the temp needle ran higher. I have no issues whit dirt or water.
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816241
I was think bout getting a vented bonnet but i was wondering about driving it in the rain, say if u stop at the traffic lights or something where the engine is gonna be hot does the rain running down through the vents directly onto the engine cause steam or anything?
I also know your no ment to directly cool a hot engine incase some cracks goin from hot to cold that quickly
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816490
look up the 270R 200sx tuned by nismo
have a look at what they did it would be hard to spot if yor painted the whole lot in the factory colour
the hole I cut is very small and only just behind the radiator shroud and stops just before the rocker cover
hmmm maybe dont have a look lol
just refreshed my memory and its not how I remember it
my advice cut hole in bonnet not frame no one likes a floppy bonnet
fill hole with mesh paint mesh black tada
function without the wank
Edited by 1400r
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816516
Well what some people do is place a number of washers where the hinge bolts on effectively lifting up the rear of the bonnet letting air escape out the back. You may also need longer bolts.
You could do this before a track event and then put it back to stock afterwards.
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816771
Mmm. I think that would look a bit wierd personally, someone got some pics?
Yes it looks weird. Heat isnt a problem on the street when you're talking a turbocharged engine of course theyre going to get hot. It's good to keep things cool yes but the engine bay has been designed with a higher temp in mind from the factory.
On the track where you're seeing a great deal higher temps is when you need to worry about it and think about getting temps down or moving air around or keeping heat inside the exhaust etc.
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816794
Thanks all
hey mate, i recently got a z tune vent moulded into my 32gtr bonnet i noticed around 15+ degree drop in engine temp.
and rain gets in. but i dont really notice it bieng dirty or anything. just made sure the seal around my cam covers and coils is in good form!
just adding to the thread after reading the rest of it.. i have been pulled over by police on a number of occasions and nothing ever mentioned about the bonnet, or headlight.. or anything for that matter.
Edited by Angus Smart
https://www.sau.com.au/forums/topic/151325-bonnet-venting/#findComment-2816925
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
