Power Bans. Water Police. State On Fire.
The politicians are what's wrong with Victoria. They wait until things are at a point where they are forced to do something. We need people who are going to act to resolve a problem before it happens... its just like Noble Park - but that's another thred - lol... there is so many things they could be doing and should be doing, every one saw this coming a mile away. Its not like the dam was full one day and then almost empty the next. It's like the kid that leaves his home work to the last min and rushes it and gets an E, but gets bumped up to a D because he has a pretty cover... that's what the government is doing...
/rant ova
Edited by Helio
So this is why all you people decided to move to QLD :) I leave my sprinklers on all night long here, no water restrictions :yes: Never had a power failure in neraly a year since I have lived in Rocky, sucks to be Victoria but, with all those bushfires, I hope no one gets killed..........
It will only become a bif deal when there is a man in a chicken suit running the state........
Oh shit it's a big deal!
Haha a man in a chicken suit... but the person running the state is the man who wears the chicken suit but only on weekends.... :)
Yesterday was all f*kked up mang, no air-con, washing stopped half way through, couldnt even relax and watch t.v for like 3 hours! haha. Or shower!! ice cold showers a :)
Sucks to be you if you have an electric hot water system, but either way, there's no way that any shower could have been "cold" yesterday, the temperature of the water coming out of the cold tap was anything but cold.
.....and why would you want a hot shower when its 40 degrees? :no:
pretty much. like selling half our water to NSW when they needed it. then going oh wait... f**k now we have none. WATER BANS FOR ALL.
pity teh fool with no power.. muhahaha :no:
i know ay, kinda makes me glad im in qld most of this year. still considering moving to melbz man? haha
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
