Haha I can relate. I told my neighbours to go f**k herself cuz she thought I was speeding in out court (loud exhaust) was actually the neighbours mum. He is a cop. Comes to my door to talk to me and whilst he was talking told him to get off my f**king property and slammed the door in his face :D
Wow great job at being civil. Perhaps if you were friendly and explained the reasoning for why she might have thought you were speeding when you weren't might have gotten you somewhere.
If you talk to a cop like that then he will go out of his way to mess with you.
  • Replies 427
And if they do that they are not behaving like a Police Officer should be and they get in trouble like an unfortunate Constable up my way :yes:
when you know the servo guy's name and he notices if you don't show for a week :D
I work in a servo and this happens all the time. I have plenty of regulars I see either daily or a few times a week. But none of them are skylines!
Seriously, I see Skylines drive past all the time, and none of you come visit me :P
Seriously, I see Skylines drive past all the time, and none of you come visit me :D
what servo though haha
-you know that downforce actually helps
-you spending ages thinking/searching for ridiculously sized rims (18x14s)
-you avoid cops at all cost (well maybe that's a victorian thing)
-you plan trips are where BP station are.
-you plan ridiculous modifications to the car, research parts that you ll never buy or be able to afford.
You know you drive a skyline when:
-you have developed a highly sensitive "skyline sense" that tingles the back of your neck and makes you feel paranoid whenever you are within a few hundred meters of police presence and/or camera's, far before any of your mates even realise there are cops to their amazement
-Your car has a strange power which effects the minds of a small portion of australias population. Causing them to momentarily slip into a rage of swearing and making obscene gestures at your car, whilst you drive at 5kph under the limit. Otherwise friendly looking old ladies seem to be the most susceptible to this mysterious power.
-parking your car near a group of 30-40yr old blokes that are standing around chatting, has the uncanny effect of steering their conversation in the direction of bathurst in the early 90's.
Edited by Crackfox
  • 9 months later...
Both already said:
You know you drive a Skyline when you see another Skyline on the road and feel compelled to tell everyone else within earshot.
You drive your $30,000 350Z as a daily because you don't want to wreck your $8000 R32 GTST
"..you drive it slowly on the road just to admire your ride on the reflection of the glassy-buildings, and you tell yourself "Damn..that's hot!" lol"
Guilty!
when you see stove plate lights in the distance at night and go to catch up to see if it's a skyline, only to find out it's not a skyline lolz.
when you wash and chammy your car, and you inspect the paintwork meticulously for any chips, bugs and tar, then spend hours fixing, polishing.
when you have the local tow truck on speed dial!
when the local auto parts shops know you on a first name basis.
when you just have to have the skyline under cover when parked.
when your suspension is harder than the V8 supercars(a twig feels like a branch when you run over it).
Guilty of all three. Expect the local parts shop knows me by face only. Not name yet. I keep changing where I buy stuff.
You know you drive a skyline when you rejoice at a local businesses bankruptcy because it means there's a parking spot available where you can see you car from your desk.
LOL - agreed. It takes me hours to get over even minor damage I've just noticed ;p
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
