Spotted luke driving his beast past 188 collins at lunch time today! eh weekend work is ghey:(
would that be me?
Spotted a council worker hitting the back of my car with some metal hose thing while i was waiting for the lights..... :laugh:
....hope they liked the black marks i left behind....and the abuse
Edited by -GODZLA-
:laugh:
would that be me?
Spotted a council worker hitting the back of my car with some metal hose thing while i was waiting for the lights..... :)
Thats no good Luke, Did it mark your car? :)
spotted and chatted to luke in his GTR last sat night, comin back from town via taroona. btw hows the new 33?
reckon one of those black 32's ppl are seeing round kingo could be me, picked it up bout 3 weeks ago, has bronze/shadow gold 17's
does anyone know who has that black 32 with the wierd rear wing? kind of looks like a 33gtr wing, seen it around kingo a fair bit.
Ah yes, good to meet you...Forgot your name as i said i would...(im bad with names) i met quiet a few skyline owners last w/e.
gfro
r33_browny
r32gtrpower
and a couple others.
hope to see you on here more 'gfro' . keep your eyes peeled for the big state cruise.
and one slap on the wrist for thinking the GTR was a Gts-t.... :):)
haha yeh sorry GODZLA, theres a few gtst's running round dressed up as gtr's but a quick look under the bonnet set me on the right track. any ideas on wat month the cruise will be?
btw good seeing a few skylines (r30, r31, r32, r33) at the collinsvale hillclimb, too bad i couldnt go in it this year
Edited by gfro
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
