spotted a black 32 GTR the other morning on the brooker, black, factory wheels new rego plates and a HKS super dragger exhaust, looked clean and tidy!
Ah yeh cheers, that would be me. In the afternoon I assume?
And I spotto'd a mostly skyline cruise parked on the side of the road in oyster cove about 12:30 at night on friday, was anyone from here part of that?
Edited by gfro
  • 3 weeks later...
spotted a m35 in Launceston yesterday on the corner of St John and William st, I only just got a very short look at it as i was to busy watching the 180 in front. I am guessing it is rickzx new stagea.
Hope to see more of it around the place
i saw a silver m35 cruising through newnham/mowbray
i've seen it a few times now, looks pretty nice
Spotted a white r34 with black bonnet damaged under the overpass that is just before the turnoff for Harvey Norman in Launceston this morning. Tail lights appeared to be popped out, but couldnt see the passenger side for damage.
Also spotted at the same spot was a red car with what looked like a badly dented drivers side.
Anyone know what the go with that one is? :|
spotted. my car with no engine and gear box.
spotted rb30DET being built.
spotted adjustable rear arms
spotted custom differential now off run in
spotted my girlfriend offering to pay for my dome top pistons
spotted useless weight adding parts in wheely bin lol
  • 3 weeks later...
spotted, just about every 32 GTR in the state at baskeville today, great turn out...
oooooooooo and poor old Funz's GTSt keeping it's self warm with a small under bonnet fire, at the side of the track :)
turns out one of the braided lines split on the starter motor so oil pissed all over it, then caught fire and melted through clutch line and that kept going lol.. from what we can tell engine is fine, just gotta fix burnt wiring and replace what ever hoses/lines need replacing . hopefully done before domain HC!
if there's anything i can do to help, just let me know old boy..
oooooooooo and poor old Funz's GTSt keeping it's self warm with a small under bonnet fire, at the side of the track :worship:
Yeh was quite a turn out for the 32 gtr's. Mine was the black one with out the stickers. How many of the other fella's running at basky are on the forum?
black 32 gtr- me :D
other black 32 gtr - ?
white 32 gtr - ?
gunmetal 32 gtr - ?
blue 32 gtr - ?
Edited by gfro
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
