I have been hearing about RB26 blocks slitting/cracking lately. It has now happened to 4 RB26s i know of, with them typically producing 320-360rwkws.
Is it a common problem? Is there anything that can be done to prevent it?
...i should add the examples i know of do track work, so it may not be the case on everyday cars that dont get put under constant loads/stress...
https://www.sau.com.au/forums/topic/153329-cracking-rb26-blocks/
You should add examples.
I only know of a couple and they were pushing some big numbers.
Now find me an RB26 head with all your contacts. I don't want to have to fork for a whole engine to separate. ;)
I've cracked 2 in my Skyline life time.
When we sent the 1st one to see if it could be repaired, we got a phone call within an hour saying there were 7 cracks on the deck alone. Not even worth doing an xray on it.
The second block had a hairline crack b/w 3 and 4 and the bores were no longer round :rolleyes:
Both these blocks were used to make more than 600awkw though :yes:
Is there a common cause for block cracking?
There is an article floating around (seen it on this forum), that covers the Gibson GTR over the period it ran in the Group A era. It mentioned something about block cracking being caused by harmonics and the fix was different engine mounts.
Very interesting indeed! I just tried a search and came up with nothing. Maybe I'm just shit at doing searches...
I have seen several cracked RB26 blocks ( all on GTRS though). Around the oil feed mostly , all had over 300awkw, all with aftermarket turbos, some 86mm bore , some oversize. At first they seem to just loose coolant but eventualy the crack goes throught to the bore . All the cracked blocks I have seen are the standard 5u blocks ..
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
