Very nice power output. Also my primary long term target & no doubt would hit 300 on a cooler day.
im not concerned at not hitting 300 in the slightest..
its only a matter of changing the boost up another 2 psi and i will be back up to 320rwkw
simple...
but i asked shaun for a strong everyday tune thats why we left it where it is now.
  • Replies 48
Posted Images
simple...
Yeah absolutely. 0.1KW extra is hardly gonna be noticeable when ur cruising the 'burbs. Right now I'd be very happy with 200KW, but of course that will only last so long....
Edited by JazzaR33
anything past 260 rwkw's is next to useless with the auto anyway.
If i hit the go pedal in first as you come on boost it spins the wheels hits 7000rpm changes into second hits 7000 rpm changes into drive hits 7000 rpm then changes into overdrive...
1st gear to get any sort of traction i MUST stay below half throttle, second gear is about 2/3rd throttle so i cant really plant it until im doing over 100klms, then i back of at 110!
so whats the point?
Hmmm would a better suspension setup help with traction?? just a random thought...
Sounds like its time to buy a Stagea and transfer your mods across...now THAT would be quick!!
A little extra weight, but your traction issues would disappear >_<
Nice result however...
can i be your wife :thumbsup::laugh::huh:
lol 299RWKW the kids must love being taken to school in that i know my daughter loves mine and i sometimes hear boys say thats a skyline
'it sure is jimmy, it sure is'
you betta have plenty of beer and a singing Elvis!!!
You need to change the diff gears by the sounds of it,
mine did exactly the same with 4.11's, went to 3.45's and problem
solved, even with 370rwkw on shauns dyno.
cheers
darren
hmm mines the standard r33 auto sedan so guessing 4.3's
where can i get somthing in the low 3 range? that would be heaps better.
what other diffs with 3 ? ratio will bolt into the r33 gtst?
cheers
Im pretty sure certain models of s13 silvias had either 3.7 or 3.9 diffs, not sure which was auto or manual.
Theres defintly a 3.9 ratio you can get for the R200's, and i am pretty sure you can get 3.7's.
I think silvia autos had 4.44's and manuals had 4.11's, i'm no R200/180 guru though.
If you have 4.3's, that would be bloody horrible, 3.7's would be the pick of the bunch if you get them,
Mines a aus R31, so i just got the gears out of a vl.
cheers
darren
The S13 180 SR20DET's manuals ran with 3.9's.
47 teeth ring gear, 12 teeth pinion.
The Q45 Infinity R200 VLSD runs a 3.7 ratio.
Whats also interesting is the Q45 run the same larger GTR 31spline GTR 6 bolt (1x6) axles.
so what are you telling me?
what do i need from a q45 infinity to run the 3.7 in my 33?
is it just the centre? or do i need to change axles etc.
thanks heaps for the info!
You have a few choices...
1. Use your pumpkin, center, half shafts and axles.
Grab the crown and pinion from the Q45 lsd and drop them in to yours. You'll have to get the backlash etc setup so thats more $$.
2. Use the Q45 Pumpkin, q45 half shafts with a set of GTR axles.
Grab the whole pumpkin (from memory they run the same front pumpkin mounts as the R33) and bolt it in with a set of GTR axles and hubs for stronger arse end. Still more $$ but not wasted on setting up backlash but rather a set of nice fat splines.
3. Use the Q45 Pumpkin with your existing Axles and half shafts.
Grab the whole pumpkin, rip the center out, pull it apart and drop in the guts from your origional lsd (viscus hub, spider gears etc) and bolt it together and not have to worry about setting up the backlash as you haven't played with swapping the actual centers. 'Shouldn't' cost you any more than the cost of the q45 pumpkin.
Did you follow that last one? Not sure if I was too clear. :P
The idea of the last one is you need to swap the spider gears and vlsd hub around as the q45/gtr's run a bigger more spliney half shaft. Using your origional spider gears and viscus hub you can simply slide in your existing 5 bolt half shafts
Obviously with the usual R200 swaps you'll have to use the backplate off your existing diff.
You'll also have to double check the front mounts. I'm certian they looked the same as the 33 pumpkin.
Thats if you want to retain the vlsd. It should still be in fairly good nick.
The 300ZX diffs are an R230. 230mm so a 9" diff.
They are tough as but unfortunately they don't bolt up. The 300zx diff's from memory are a 3.69 ratio and run the same chunky axles as the gtr/q45's.
In the SA section there's a stickied wrecker listing.
http://www.skylinesaustralia.com/forums/in...howtopic=123889
Ring every wrecker and see what they can do a pumpkin for.
The going price is generally around the $250-$300 mark. 'SOME" absolutely rip people off.
A good example is D1 garage.. $500 for a GTR Pumpkin, another *won't name publicly* wants $500 for a VLSD S13 pumpkin. :S
So ring around, some may also be able to supply just the ring and pinion depending on which way you want to go.
You may be able to pick one up for cheaper over at www.nissansilvia.com, remember to double check the ratio either way.
Simply pop the rear cover off, on the crown wheel there should be stamped something along the lines of 47:12 with a few other numbers. Simply divide 47 by 12 to give you your ratio.
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
