can i get the address for the crossroads servo and time thanks....if thats the meet point
The cnr of Camden valley way & cambelltown rd/hume highway as u turn down onto the freeway there is a truckstop just along there, big car park,say around 5.30am?
Still waiting on 2 cameras 2 arrive!cutting it a bit short i might say.
  • Replies 701
Posted Images
yea 530 sounds all right. Is it the the servo after the corner of hume and the freeway? Cant recall seeing one after. Know there's a caltex servo before though
pretty sure there is a truckstop or something there,well was last year!!!
Afternoon peoples, i've decided to pull out of the trackday this weekend as i'm not 100% confident in my car staying in 1 piece (mainly my gearbox which as everyone knows has been bad for a while)...
Hopefully everyone understands, as i'd much rather get everything fixed up, including better pads as Oz GTR suggested, some decent tyres and than hit the track.. Unfortunately i'm not in a position to have anything go wrong especially down at Goldburn...
I'm still going to come down and spectate (maybe even jump in for a passenger ride if people are still willing to take me out) and hopefully i'll have the car ready to go for the next event, which I believe might be the Texikhana..
Thanks for everyone's help getting the car ready, I was originally hoping to have the gearbox fixed, however time passes and $$$'s dissapear.. I'll catch you all down there on Sunday (just at a more reasonable hour)
What about just taking it easy around the track mate?.. My clutch is on its way out and i cant see myself fitting one on saturday before the track day so ill be driving very non agressive, i was going to pull out but i figure i can still go and have good fun even if i cant nail my car as hard as id really like to.. at least i can hit corners with a bit of speed wich should be fun .. expecialy without the worry of been done by the cops..LOL
Dave
Thanks for everyone's help getting the car ready, I was originally hoping to have the gearbox fixed, however time passes and $ s dissapear.. I'll catch you all down there on Sunday (just at a more reasonable hour)
:P Noooo...
Don't worry I nearly pulled out... but have decided to throw the wrx around for a bit of fun instead :dry: Il take you on some hot laps.....well as long as the gearbox holds up.............lol
There is still a slim chance Il take my car, just have to decided whether to bite the bullet and put the highflow/low mount back on....!
How upsetting anthony!
Haha I am never confident in my car.. I go round with nangkangs & standard pads..
Chances are.. if your car is going to brake.. its going to brake no matter where it is and what you are doing.
I hope you will still be coming down to watch :dry:
Awwww that sucks! It's completely understandable though. Andy's had a few troubles with the 32 in the last week or so and there is still a mysterious vibration that needs to be fixed in the next 2 days :dry: the shop is doing all it can to get it done on time though.
Atleast you're coming to spectate, i'm sure many peeps will be happy to have you ride along :P
Thanks everyone.. unfortunately unless I can go down there with full confidence I won't enjoy it, also a couple of other things needed to be done to get it ready in time including new tires + gearbox oil change.. so i'm going to save the cash, get the box done and head too the next one..
Your right that the gearbox could let you at any stage, however i'm a lot kinder to it on the street than when doing flat out laps around a track >_<
Anyways, will definately still be down there watching + getting some photos.. And now i'm feeling more relaxed not having to rush stuff..
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
