  • Replies 701
Posted Images
I'm actually trying another pad from Bendix, called the "Street, Road, Track"
http://www.bendix.com.au/Text/117425913098...281613041-6043/
They have it for the 350Z non Brembo callipers, so I'm hoping it should fit onto my V35 non Brembo's.
I'll find out Saturday morning when I try and fit it.
Fingers Crossed
Hi All,
Does anyone have a small box trailer they are willing to loan me for sunday or if they are already getting a trailer towed down there and have space id like to bring along a compressor, generator, toolbox,impact gun, tyre pressure gauge and semi slick race tyres x4, i have a towbar fitted to my car with wiring and the person or persons loaning the trailer will be able to use my gear as needed please PM me or call me on 0410 456 781.Also if someone would like to share the hire of a box trailer please contact me, cheers.
Carlo
Hey mate there is power and a compressor in the pits at wakefield - so unless you are planning/expecting to have a heap of trouble don't worry about it. Just get there earlyish and grab one of the first few garages. We only have 40 cars entering so there will be heaps of garage space.
4x tyres fit in the back of a 33 OK, easy if there is no seat or a bit tricky if it is still in.
well my engine finaly died ;) i have 4 broken pistons, ringlands to be exact. i dont think i have time to do an engine swap after work today, but wel see.
needless to say i wont be racing.
Daammmn. Sorry to hear that mate. I was really looking forward to seeing your car tearing around the track. :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
