I was hoping to get down to watch/photograph this but I ended up getting roped into work so won't be able to make it.
I was down there 2 weeks ago tho and this was the scene - Hope its not quite so bleak for you guys...
Yep, thats frost - Pfft as if you need an intercooler :worship:
Oh yeah, and the puddles were frozen over so bring your ice skates
  • Replies 701
Posted Images
Go Dave.
Big effort queenslanders!
Is anyone going to UAS for supplies tomorrow morning before the track? If so maybe you could pick something up for me and bring it down.
Sucks to hear, Dave, but I hope putting it back together and tuning it goes well.
Man, you Queenslanders are also pushing boundaries - hope you and Bunts have a good time while you're down.
Bah, Adam, if I'd known I would have grabbed it for you to bring along to the Ignition DVD meet at Homebush.
Well we might be 1 person less, my WRX mate just called to let me know he way at the mcdonalds on the hume. I thoughjt it was funny but for some reason he did not see the funny side. He is busy tomorrow and probably cant make it, but he will try.
I on the other hand just found out my L2S has expired, what are my chances of getting it renewed today?
sad to say after a massive effort the boys at the workshop fell a little short, car is sorted now but we wouldn't have gotten there till 4am :thumbsup:
So now it is in getting a permanent fix to the problem rather than a temp one, we will be down in a month or two for an open day!
Andy.
Oil Cooler FINALLY on.. what a pain in the ass should of just paid someone to install it <but got quoted $300 kinda put me off> slept at 4am this morning :)
Then after 3 hours sleep wheel alignment at 8:30..
So pretty much ready to go just need to fill up petrol & jerry can and get some sleep
SEE EVERYONE TOMORROW HOPE THE WEATHER IS GOOD ;)
Ray, can you please bring a heater.. Its freeZing.. Lol..
Yep had the same problem but couldnt get mine in dam it. i still be there tho.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
