turbo way too small? 1 bar of boost should have seen pretty bulk power on a correctly sized turbo.
faaaat torque curve, like it!
i have a Q45 AFM too - reckon you could let me know what your pinouts were on it, and what colour the wires are? mine go WHITE, BLACK, RED in the direction of airflow. i'm assuming SIGNAL, GROUND, +12V but nobody can give me a straight answer :)
I think the 80mm pod adaptor is causing issues as it blocks off the outer 10mm or so of the afm. Possibly causing a high speed stream of air through the center of the 90mm afm, this is why it runs so rich.
The rb20det pfc loadpoints maxing out is an interestering issue.
Mine with the stock turbo at wot uses load point 19 across the rev range.
Changing my AFM fromt he rb20 to Z32 item changed nothing with regards to load points used but it did change the afm voltage.
In the PFC manual it does state that the H/C is only good for mild mods, bigger mods including cams etc it suggests you need the software to modify the actual base map?!
Strange but true. I wonder if this is only an issue with the rb20det pfc.
Also at WOT Darrens car is running (AFR) initially in to the 10's then comes up to the 11's by peak power, it cannot be leaned out any more. :(
So there are a few little rwkw's available.
Darren did you check if boost it tailing off at high rpm? It probably is when you consider my stock rb20det turbo tails off to 9psi by peak power and makes 24rwkw less (176rwkw).
Bl4ck32 & my dyno run
63km/h is approx 2000rpm
132km/h is approx 5000rpm.
I suspect mine wheel spun a little from 70-80km/h, hence the dip.
The torque curve doesn't represent the ignition table.
I would like to check out your ign. table Bl4ck32. :)
Mine is running bugger all, 17degree's at around 2000-2800rpm then it drops to 16degree's until 4000rpm where it drops to 15degree's.
Its very interestering how your T3/4 bush bearing turbo with its large turbine wheel spools almost identical to the small RB20DET turbo. :(
Mine with the stock turbo at wot uses load point 18 across the rev range.
Thats what Shaun said it did with mine. He needs to see if changing one of the correction tables helps with the fueling issue...
Id say boost does drop off higher in the rpm...i didnt check, but its almost a certainty. There is more left in the turbo, but no room to tune.
Ill call ya today or tomorrow so ya can have a looksie at the settings....
The overlay definitely doesn't do your car justice Bl4ck32.
It seriously pulls so much damn harder than mine. :(
It hooks up damn well with that 2 way.
The difference in spool between your T3/4 bush vs my stock rb20det BB turbo is nothing.
Which honestly suprises me, yours has quite a larger turbine wheel and compressor wheel, not to mention its bush not ball bearing.
Its given me motivation to get off my arse and earn some money to put towards a new turbo. :)
I'll definitely be happy with a fairly cheap VG30DET highflow.
having just read every single page of this thread from start to finish its definitley one of the best ive read on any forum
im another nzer and are building an rb30de engine at this stage. i drive a nissan cefiro with a laurel front current with the sohc rb30. atm its running a rb20e intake manifold and injectors and the 20e loom and computer
here the laurels come out with an rb25de. if i can get the engine out of one of those, can i take the stock loom and wire this to the stock computer and i presume it will run the 30 until i get it turboed
cheers
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
