you certainly could low mount it, but it'd need a custom manifold. i have a GT40 1.34 rear and this is how big it is:
as you can see there's not a lot of chance of putting that anywhere near a standard manifold. it would be reasonably easy to do a low-mount tubular manifold and keep it so that the returning cooler pipe still made it over the top however.
the GT40 will make the power more easily (less boost) but your bottom-end power might suffer a bit. having said that, with good cams and good tuning there's no reason an RB30DET can't have brilliant off-boost response. it would build boost pretty quickly no matter what turbo is on it IMHO (within reason - GT60 GTFO)
the 35/40 1.06 rear would be a brilliant match, you'd have to push it pretty hard to get 320rwkw though.
Would you expect the need to increase the injectors for the GT35/40 and better cams ?
Apparently the ECU needs upgrading as it only supports multipoint.
This I'm unhappy about...
About rods. This bloke Brad Goucher ( [email protected] ) gets custom made 4340 forged steel H beam rods especially for the RB30. Not a modified chev rod or anything. Also come standard with ARP2000 rod bolts and they are a very nice price if you ask me.
I havnt used them personally yet but i think im going to sway this way when it comes time for rod's. Send him an email for some pics. They look very nice to me.
what sort of power would guys think that an HKS 3040 with 1.12 AR rear housing would make on the RB30/25 with tomei poncams?
would that turbo flow enough for 400rwkw or so?
reason i ask is because i have finally found a block for a good enough price .. not super cheap but the best i found so far.. so im picking this up on the weekend and getting started on the build..
What kind of prices does he charge?
what spec cams are you considering ?
my mechanic thinks the 256 deg is the best for street driving.
longer duration needs more lift to be optimal.
Edited by conan7772
my mechanic reckons the 256 deg are the most agro ones you can use before the lobes start to hit the sides of the head...
still don't know if this is for sure yet.
FYI - 9mm lift is where the cams require the head to have some material removed for clearance. Duration doesnt affect it. Larger injectors can be bought that fit to the oem fuel rail.
Maybe do some more research...
Edited by Bl4cK32
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
