you certainly could low mount it, but it'd need a custom manifold. i have a GT40 1.34 rear and this is how big it is:
as you can see there's not a lot of chance of putting that anywhere near a standard manifold. it would be reasonably easy to do a low-mount tubular manifold and keep it so that the returning cooler pipe still made it over the top however.
the GT40 will make the power more easily (less boost) but your bottom-end power might suffer a bit. having said that, with good cams and good tuning there's no reason an RB30DET can't have brilliant off-boost response. it would build boost pretty quickly no matter what turbo is on it IMHO (within reason - GT60 GTFO)
the 35/40 1.06 rear would be a brilliant match, you'd have to push it pretty hard to get 320rwkw though.
Would you expect the need to increase the injectors for the GT35/40 and better cams ?
Apparently the ECU needs upgrading as it only supports multipoint.
This I'm unhappy about...
About rods. This bloke Brad Goucher ( [email protected] ) gets custom made 4340 forged steel H beam rods especially for the RB30. Not a modified chev rod or anything. Also come standard with ARP2000 rod bolts and they are a very nice price if you ask me.
I havnt used them personally yet but i think im going to sway this way when it comes time for rod's. Send him an email for some pics. They look very nice to me.
what sort of power would guys think that an HKS 3040 with 1.12 AR rear housing would make on the RB30/25 with tomei poncams?
would that turbo flow enough for 400rwkw or so?
reason i ask is because i have finally found a block for a good enough price .. not super cheap but the best i found so far.. so im picking this up on the weekend and getting started on the build..
What kind of prices does he charge?
what spec cams are you considering ?
my mechanic thinks the 256 deg is the best for street driving.
longer duration needs more lift to be optimal.
Edited by conan7772
my mechanic reckons the 256 deg are the most agro ones you can use before the lobes start to hit the sides of the head...
still don't know if this is for sure yet.
FYI - 9mm lift is where the cams require the head to have some material removed for clearance. Duration doesnt affect it. Larger injectors can be bought that fit to the oem fuel rail.
Maybe do some more research...
Edited by Bl4cK32
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
