We went CP flat top pistons. But its upto you what pistons you want, to achieve whatever CR. Our tuner wanted us to go with a lower cr, while others tend to go for the higher cr.
The view is the lower cr makes the car less responsive off boost, while the higher cr makes it more responsive. However depending on tuning the lower cr helps with less knock and allows more ignition advance and boost without the knock, while the higher cr helps with more low/midrange power but in alot of cases ends up with more knock....but it all comes down to the tuner in the end or so everyone says. Prob abit in it with fuel economy and other bits and pieces, but .5 difference is like either choosing to run rb26 cr or running rb25 cr...in the end its upto you cause its your engine your building.
But then again it depends on what application your building this motor for.
Edited by r33_racer
howdy just about to order some pistons for 30det.
can get a good deal on acl rebuild kits and the new forged pistons they've produced.
does anyone have any experiance with these suckers? are they any good? or shall i pay a few hunj more and buy eg arais??? dont really wona spend teh extra dollars coz i will also be getting Hbeam rods.
also these acl forged pistons apparently produce a comp ratio of 8.5!
is this ok for a daily driver which will cop a bit of shit with about 420rwhp???
the car is a r33 is thats gona help.
except those pistons are suited for a rb30ET not DET. I think it will give a shithouse CR something like 7.1:1 its been said. You need the NA pistons to give a better CR around 8.2-8.5 or thereabouts.
No they are 8.5:1 in the RB30ET engine, so when used with the RB25 head they come in around 8 depending on combustion chamber size. I have used them in my RB30 with R34 Neo head ( it has a 58cc chamber ) and comp has worked out at 8.4:1
You are correct in what you said if you use the std oem turbo piston from the VL RB30ET. They were around 7.5:1 std I believe.
Best to use the CP pistons like I sell.
Edited by Spoolup
So what compression do you get with your pistons SPOOL
CP make two types
8.5:1 and 9.0:1.
One has a flat top with zero deck height and the other has an 11cc ( from memory ) dome.
Thanks for that spool, just wondering Is their any issues using oil restrictors with VVT.
Edited by JMCY
seeing as ive got this motor apart
should i use restrictors if im using an RB25DE head and RB30 oil pump?
the isnt going to be raced very much at all, just a weekend cruise and a dyno run here and there
yes on an RB26 head block off one and use a restrictor in hte other, size depends on oil pump
i picked up my sump adapter on thursday and i'm going to install it this week, so i'll document the whole process (with pics) and post them up here
rb25 head with n1 oil pump and one blocked off and 1.5mm in other and we have oil problems. Circuit racing is a bitch for exposing problems.
oh and we have vct as well.
Refer to the table from SK's oil control problems in rbs info.
Edited by r33_racer
Hey guys been reading this thread for a while now almost an hour lol
just a few qik questions...
i have picked up an rb30 complete do i need a n/a rb25de head or can i use an rb25det head as there is one that has been ported and polished? vct or non vct
also this rb30 has been rebuilt to std specs like 400kms ago is it worth just fitting the head and fix it if it breaks. I work in a performance workshop so rebuilding it is no problem i was just curious if anyone has pushed the std n/a 30 bottom end to breaking point?
cheers
I would just bolt them together with the restrictors and remote oil feed to the vct. Cc your chambers and pistons( you dont need to pull them out) and chech your deck heights to find out your comp and squish, i would go for high 8's:1 comp amd about 35 thou squish, so you may have to deck the head or block of fiddle with head gasket thickness, get a steel head gasket and your done. Dont try to get 1000hp, and it will hold together. You may wish to put a good set of big end bearings in it though. This should be good for a safe 550hp if tuned well, as above this the rods go
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
