Interesting.. Whats with the 2 lumps in front of each cam shaft on the cam belt then? :P
It was an N/A that I had a look at, I wouldn't have thought the turbo head would be any different.
??? The cas still bolts to the front of the exhaust cam, but it has a different spline
Are there any differences in the 26 and 30 headgaskets?
I have a VVT 25 head thats had the front right water jacket and oil gallery welded up and the water gallery shaped to suit the 30 block.
There appears to be more thicknesses available for off the shelf MLS headgaskets for the 26.
is there any issues running the RB25 gasket with the rb25det head?
obviously the oil feed is different, and will be modified for VCT externally..
Nope. I'm running the Cometic RB25 head gasket on mine without issues (~40,000kms). The price difference between the rb25 and rb26 was considerable at the time. I got mine from memory for $150.
Nope. I'm running the Cometic RB25 head gasket on mine without issues. The price difference between the rb25 and rb26 was considerable at the time. I got mine from memory for $150.
i got mine cheap but not THAT cheap ...
the rb25 cometic im running on the rb25 in the car cost me $330 :D
got some ACL piston rings, so its almost wash and build time :O prob 3 weeks
Thanks for that Cubes.
I've been looking at the cometic and ACL race series MLS gaskets, Prices ive got ranged from 210-350 for an RB30 MLS headgasket.
Its not really an issue with a 33 25 VVT head that I've seen but there is a 1-2mm of sealing on a particular spot on the front right water jacket. That is when you use a 30 block.
Just to be on the safe side I tigged the water jacket and VVT gallery up in the head and shaped it to suit the water gallery in the 30 block. Theres a min. 5-6mm of sealing now.
It was a better option that trying to braze weld brass to the side of the block like in this pic.
http://www.users.bigpond.com/twinvl/blockmod2.jpg
I heard the Non turbo rb30 pistons have less rings or sumting like that.. and dont cope with boost very well...
wen i was gonna turbo my rb30e, i was being told that the compression had to be lowered a fair amount from 9.0:1 to around 7 or 8:1 to stop pinging and detonation...
Why is it ok for a hybrid motor to have higher compression ratios? wont it ping/knock its tits off??
Jimbo
Whoever told you that didn't know what they are talking about
Jimbo
Jimbo
putting the 25/26 head on actually lowers the compression!
1. Because its a hybrid motor. Better designed head that allows you to get away with a little more static comp. :)
2. Its all in the tuning. Simply throw a stock rb30et ecu on an rb30e that has a turbo bolted on to the side of it and try to push 14psi through it and it will almost certainly detonate. So tuning tuning tuning.
So the guys running the R32 RB25DE heads. What sort of power are you guys putting through the inelt manifolds...has anyone gone to an aftermarket one and noticed an improvement in response/power
Hey fancy seeing you in these neck of the woods. :whistling:
AM-Performance is about to drop an aftermarket plenum on his within the next week or two.
Sky30 pushed 312rwkw through his r32 rb25de head running the stock exh. manifold and stock inlet manifold/plenum.
Thats the highest I know of on the R32 RB20/25 style plenum.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
