gday guys. im currently building an rb26/30 for my vl turbo, i will be using an autronic and a 1000hp ta45 turbo.
Just wondering which pistons to use? If I buy CP forgies that come in 9.1 comp ratio it should drop to the perfect
comp ratio once the head is on yeah?
also, do i need to run the oil squirters?
thanks
brad
Fair enough, i stand corrected
Just assumed a 20yr+ old motor would be more prone to failure, especially when almost every VL in the country has been flogged to death :dry: .
i've heard stories that the old school v8 boys looked for 300,000km+ blocks for thier mega hp builds, and wouldnt use fresh, new blocks, because the old ones have been well seasond and the like, dunno how true that is though
I thought that was due to holden putting an inefficient and undersized radiator in the vl...while nissan actually knew what they were doing...hence why vls have overheating problems and the r31 didnt....is that true?...i actually heard that from several holden nuts!
R31's still cracked the sohc heads. BUT it was less common as their cooling system was just that little bit better.
Just a design flaw of the SOHC head.
Overheat our DOHC heads and its very rare to crack one.
nah, they just become pourus and bend...:)
I thought it was due to the fact that the VL radiator sat lower than the top of the head where as the R31 didnt ?
This leads me to my next question:
As the head is sitting an inch higher, is this going to cause problems; just like the radiator issue in the VL?
Do i need one of those custom remote radiator fluid reservoirs, thats mounted higher in the engine bay?
Don't loose sleep over it. The head sitting higher than the radiator isn't a problem providing its bled correctly + I don't believe its anywhere near sitting higher than the radiator, those big rocker covers pump it all up to make it look like it sits higher.
The SOHC head cracking is simply poor head design.
If the SOHC gets a little too warm the heads crack.
R31's have a better alum. radiator that keeps things cooler, a better more open front end that allows more air to the radiator.
VL's biggest and most common problem these days is the radiator's baffle design that rusts allowing water to bypass the core; as a result they get warm and crack. Then there's also the failed viscous fan that fails; temperature creeps up and bang cracked head. Of which also applies to the R31's. I've seen a few also have blocked coolant passages in both the block and head/plenum/inlet. All of which are age/lack of maint. related. :D
Do a little google..
http://www.google.com.au/search?hl=en&...acked&meta=
Fear not, its just the crapo sohc head design; aus market... chances are it was a rushed job, why sink the development $$ in to a market that is so small. :(
yeah it was a pretty restless night. couldn't believe how quickly it caught, ran and idled smoothly - pretty much straight way, with instant pressure. at least if it's a dog on the dyno I can turn it into a giant water pump and use the RB26 to run it. just got to concentrate on the niggly things that are bound to arise. last night was filling it with coolant, then heard it hitting the floor - thinks oh fark what's that - and it was the banjo that goes into the block - about .5 of a thread too long and the washer didn't seal. running long dumps so getting it out was a bugger, but an hour later and with some judicious application with a hacksaw no more leaks.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
