gday guys. im currently building an rb26/30 for my vl turbo, i will be using an autronic and a 1000hp ta45 turbo.
Just wondering which pistons to use? If I buy CP forgies that come in 9.1 comp ratio it should drop to the perfect
comp ratio once the head is on yeah?
also, do i need to run the oil squirters?
thanks
brad
Fair enough, i stand corrected
Just assumed a 20yr+ old motor would be more prone to failure, especially when almost every VL in the country has been flogged to death :dry: .
i've heard stories that the old school v8 boys looked for 300,000km+ blocks for thier mega hp builds, and wouldnt use fresh, new blocks, because the old ones have been well seasond and the like, dunno how true that is though
I thought that was due to holden putting an inefficient and undersized radiator in the vl...while nissan actually knew what they were doing...hence why vls have overheating problems and the r31 didnt....is that true?...i actually heard that from several holden nuts!
R31's still cracked the sohc heads. BUT it was less common as their cooling system was just that little bit better.
Just a design flaw of the SOHC head.
Overheat our DOHC heads and its very rare to crack one.
nah, they just become pourus and bend...:)
I thought it was due to the fact that the VL radiator sat lower than the top of the head where as the R31 didnt ?
This leads me to my next question:
As the head is sitting an inch higher, is this going to cause problems; just like the radiator issue in the VL?
Do i need one of those custom remote radiator fluid reservoirs, thats mounted higher in the engine bay?
Don't loose sleep over it. The head sitting higher than the radiator isn't a problem providing its bled correctly + I don't believe its anywhere near sitting higher than the radiator, those big rocker covers pump it all up to make it look like it sits higher.
The SOHC head cracking is simply poor head design.
If the SOHC gets a little too warm the heads crack.
R31's have a better alum. radiator that keeps things cooler, a better more open front end that allows more air to the radiator.
VL's biggest and most common problem these days is the radiator's baffle design that rusts allowing water to bypass the core; as a result they get warm and crack. Then there's also the failed viscous fan that fails; temperature creeps up and bang cracked head. Of which also applies to the R31's. I've seen a few also have blocked coolant passages in both the block and head/plenum/inlet. All of which are age/lack of maint. related. :D
Do a little google..
http://www.google.com.au/search?hl=en&...acked&meta=
Fear not, its just the crapo sohc head design; aus market... chances are it was a rushed job, why sink the development $$ in to a market that is so small. :(
yeah it was a pretty restless night. couldn't believe how quickly it caught, ran and idled smoothly - pretty much straight way, with instant pressure. at least if it's a dog on the dyno I can turn it into a giant water pump and use the RB26 to run it. just got to concentrate on the niggly things that are bound to arise. last night was filling it with coolant, then heard it hitting the floor - thinks oh fark what's that - and it was the banjo that goes into the block - about .5 of a thread too long and the washer didn't seal. running long dumps so getting it out was a bugger, but an hour later and with some judicious application with a hacksaw no more leaks.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
