Only in the fact that it has to physically pump more oil around (extra oil in the lines etc) Personally I doubt an oil filter relocation kit would have enough effect to actually starve the head.
Edited by MintR33
wont affect anything. We use a truck oil filter thats about four times the size of the std skyline one and its got about 1m of line to it and then it goes to two oil coolers and back to the motor.
also what sump would i have to use to run in a s15?
That would depend on where you have the motor sit in the bay, best to install the motor without the sump, fabricate the mounts to suit, then see clearances to the cross member and sway bar etc
or have a chat to Fatz regarding what they did in his S13
I haven't used SolidWorks as such, but I used to work for an automotive R&D company and there I used SolidEdge - pretty much just a leaner version of SW :) At the moment I use microstation to do all my drawings whether they be .dwg or .dgn.
</back on topic>
Waiting for my N1 oil pump and bearings to arrive then my RB30 will be running again.. after xmas will probably see a GT35R get bolted on :huh:
I'm just about to get the cams sorted from Tighe cams for mysetup.
I've been recommended by both my tuner and Tighe cams to go the 265/265 in/exh.
My only small concern is will the 265/265's lope over noticeably on idle? A mate has the 254/254 cams and the idle is baby smooth; the note did change slightly but there is no lope.
If the 265/265's do lope would the 254/265 setup smooth the idle?
I wouldn't mind a slight lope but I've been you tubing SR20's (same bore stroke) with 264 cams and they lope over like bridgy's. :S
All though the SR's do run a LOT more lift that I will be running (8.9mm).
The cams are hydraulic so no doubt slightly reduced ramp rate which may also smooth idle slightly compared to rb26 solid cams.
Any guesstimates based on sort of similiar experience? :S
Considering the cams you are running at the moment, either setup will be a vast improvement. Being that you aren't running a huge turbo, the power difference of the 264 inlet cam over the 254, i wouldnt expect to see an extra 20rwkw between the two. Its all up to you, but considering you are almost at the limit of streetable 2wd power, i would go the smaller inlet, to maintain the low rpm torque, and idle quality, but its all trial and error.
Cheers Adriano,
I do plan on dropping a GT35r .8 on it at a later date once I push the limit of the GT30.
As Uni is now all done with and I'm working I have a fair bit more $$ to throw at the car and have some fun with it down at Mallala. So it will be primarily a car I race down at the track. Similar to the Troymeister but I'd still like it to idle 'ok' so it doesn't attract too much attention. :(
I'm hoping some one has played with 265 cams in a hydraulic head and the RB30. ;)
this vid is of a 33 gtst i've help built this year. its a built rb25, solid lifter head, 260/9.15 cams, big port work both sides, os valves on the exhaust side. its just sounds pure porn at ilde (~900rpm), and u should hear it on full noise ;) *creams pants*
http://smg.photobucket.com/albums/v315/Tha...urrent=Idle.flv
Sounds very very nice. I've replayed it over and over and over. I could listen to it all day. lol.
All though partially due to the solid lifter setup. Hydraulic cams sound much smoother. :) A good thing for not being defected though. ;)
Cheers Shane. :(
All though partially due to the solid lifter setup. Hydraulic cams sound much smoother. :w00t: A good thing for not being defected though. ;)
Cheers Shane. :)
i know myself and the owner dont get sick of it hahaha
they can be turned so its not as 'raspy' on idle, but then there goes hp, and who wants to do that? :(
he's running a 35r with the .82 rear, and power tips over at 8000rpm (although 1 silicon joiner is sucking closed at high rpm so that could be playing a part in that) so i reckon something closer to 270deg would be ideal on an rb30 with the 35r
they can be turned so its not as 'raspy' on idle, but then there goes hp, and who wants to do that? ;)
[/quot
How many ponies did it produce?
You could try sourcing a set of A'PEXi 270 degree cams, pretty sure these retain the hydraulic lifter setup... from memory they run 9.0mm lift.
The downside is they went out of production some time ago so Yahoo auctions may be the best bet...
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
