How many ponies did it produce?
500 before it blew the welsche plug out, hasnt had full tune done since
How could that happen, unless the joiner is before the turbo (intake pipe)?
yeh intake pipe, the blue 90deg one in the pic
Has anyone seen a low mount tubalar manifold with external gate? I already have height clearances issues and am afraid a high mount manifold will exacerbate the problem :(
I realise that external gate on low mount will be pushing it for clearance down there but thought someone out there might have come up with a manifold design I can buy off the shelf :P
Has anyone seen a low mount tubalar manifold with external gate? I already have height clearances issues and am afraid a high mount manifold will exacerbate the problem :D
I realise that external gate on low mount will be pushing it for clearance down there but thought someone out there might have come up with a manifold design I can buy off the shelf ;)
Clearance on a low mount is not the only problem, you also have to consider accessibility of the bolts/nuts/hoses/etc for installation/fitment.
I really wanted a low mount manifold, but once i starting thinking about installation, etc. i decided to go high mount. Most high mount manifolds (if built properly) would have the turbo sitting below the level of the cam covers, so i don't think clearance is an issue; unless you're fitting a 800+hp turbo.
Only looking at fitting a GT35R and by clearance I meant for everything.. including ratchet and spanner access :P
The majority of the manifolds I have found when looking about have the turbo sitting a good couple of inches above the cam cover. If anyone knows of any specific high mount manifolds that aren't too high.. please, enlighten me :D
Only looking at fitting a GT35R and by clearance I meant for everything.. including ratchet and spanner access :D
The majority of the manifolds I have found when looking about have the turbo sitting a good couple of inches above the cam cover. If anyone knows of any specific high mount manifolds that aren't too high.. please, enlighten me ;)
I am using a custom low mount manifold with a garret 35/40 and 48mm external wastegate, it has clearance everywhere, but it is a bit of a tight squeeze.
I preffer the low mount for lower engine bay heat temps as the hot air can escape out the bottom of the car. All factory turbo setups are low mount, there is a good reason for this.....
Im making my own low mount, GT35R, Got my flanges all drawn in cad (as close to match ported as possible-RB26), & laser cut using 12mm plate for all 3 flanges & steam pipe bends. Will take some pics when I start it. Do have a spare set of flanges to if anyone is interested, also have the cad drawing to get more cut if needed.
bearclaw? is that the model one up from the cameltoe and two up from the mooseknuckle? (you know..."mooseknuckle, because cameltoe has an ugly sister") (sorry)
just ordered the ATI damper i've been umming and aahing about, $500 landed on special from Summit Racing in the US. best i could find was about $745 here, if anyone's interested get in while the dollar is flying high.
cheers
Edited by Scooby
hey wat throttle body do u run with the greddy style plenium ?
80 or 90mm ?
also for those with aftermarket comps do u use the MAF sensor ? or do i need a Q45AFM or a Z32 afm ?
also
i need to know what turbo + manifold i should get ? - high mount or lowmount in a R31 skyline.
internal or external waste gate?
i was considering this.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...A:IT&ih=014
but i was told to stay away from it ?
also going to be runnin tomei poncams.
80 or 90mm ?
also
i think the greddy style ones are for q45 TB's but you can get an adapter for a stock TB
and i would definately stay away from that turbo
Also for aftermarket TB's and fuel rails you can try Buzz Engines in Brisbane. They have done some nice work. http://www.buzzengines.com/
I need to get a decent fuel rail for the 26/30 as I'm running Delphi 680cc injectors and the O ring setup is not optimal with the GTR rail.
thats also something id like to make on our cnc's when they are up and running properly some billet fuel rails....im in love with these machines and they arent even setup fully and running...however next week they tell me!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
