Den001,
The Rb30's require a larger turbo to obtain the lag and then hard ramp on to boost you are referring too.
That same turbo on the rb25 or 26.. lag lag lag bang kick in the arse. Its the nature of increased displacement. Boost is developed over a wider rpm range.
To clarify.. is that 652rwhp or fly hp?
thats good power but for that ammount of boost, i think there is somthing wrong
I tend to agree, a 3L with a gt34r running over 30psi and only making 360ish rwkw?
Are you sure all 6 cylinders are firing?
cheers guys.
firstly fuel car is running shell v - power 98ron pump fuel.
second. it has 2 in tank tomei fuel pumps wired seperately to two relays.both relays are working and both pumps are working
we checked that plus fuel pressure is 3.5 bar too.
graphs i will put up when matt @ the racing line finally gets the car to run..
2.17 bar is not what i will run
the car is mapped for 1.5bar 590bhp/540lbs @ 5500rpm @ the fly
also 1.8bar 620bhp/585lbs @ 5500rpm @ the fly..
the graphs look like the evo graphs, torque and bhp follow each other to the top, car makes boost from 2800rpm climbs quick and steep from 3500rpm.redline at 7000
you are all right for that boost i would have expected 700bhp @ the fly and maybe 600lbs torque.cant understand why bhp is the same as torque.
when i get the graphs i will see more but at 1.8 bar it made 500bhp @ the treads which he says is 620 @ the fly..
bernie. any comments from you guys or tuners would help.
the electrical problem has got all the tuners baffled here.
if this helps the tuner, if you set the fuel map up say from 1000-5000 rpm and the afr goes from 15 at 1000rpm to 11 at 5000rpm, then let the revs drop back to idle. and do it again this time without altering anything at 1000rpm fuel is 20 and as you rev it up it goes up and down reaching 30 in some cases.>>>???? bernie
Edited by rockabilly
26psi.. 500rwhp so around 373rwkw + given its a 4wd dyno so saps just a tinny little bit more power out of the final figure.
Its close enough bah.. Only a dyno figure.
I'm sure it feels fast and will break 3rd gear if your not carefull. lol
What spec cams are you running?
With a s1 R33 25det VVT head can the bulky inlet cam gear be changed to an Rb20 or adjustable one and still retain VVT?
Reason being I'm trying to make it look like an RB20, ie cam covers, coil cover and timing belt cover.
Edited by Alf
the bulky inlet cam is the major part of the vvt, so you would lose vvt by removing it.
If you want it to look like an RB20, then find an rb25de and put all the rb20 dress up gear on it.
It is the cam gear on the inlet side that operates the VVT - so removing it or the camshaft itself will stop the VVT.
You can run a std cam in the inlet with a std cam gear or adjustable one ( so you can use the STD rb20 cover etc ) but you will lose the vvt option.
Den001,
i understand and agree with you totally, but look at the boost its running, thats big boost, for that amount of psi going thru the motor, you would think that the turbo would come into its own and it would be in its efficiency range by far..... have a look at the clip again... listen to the turbo ramping and then listen to the revs of the motor, there is not real much positive gain from the forced induction.... this is what i mean..
im not bagging the motor, it makes power, but the way it makes it is doesnt seem right, to me it seems like its a massivly decompressed motor obviously making the power but look at the boost its eating, it revs way to slow, it eats 2.1bar boost and all on 98 pump fuel.... this is the characheristics of a decompredded motor...
im building a 30/26 now, with 8.8-1 comp.. and i tell you when it comes on boost it will come on... and it will be a t04z with a 1.0rear.... and the aim wil be to make it rev like this machine....
http://www.youtube.com/watch?v=caoHNZFufHU
this is how the engines should be set up... rb30 have in my eyes a very good rod ratio... 1.8-1. if you car rev out a 26 so hard there is no reason why you cant do it to a 30... especially with a twin cam head...
Considering its only a 600hp turbo 650hp isn't a bad figure. http://www.turbobygarrett.com/turbobygarre...2R_714568_1.htm
man ive been missing out here. Gone a few weeks and everything happens. Nice power rockabilly, but thats alot of boost!
Old mate in NZ reckons he can rev out his twin cam 30's to 10k and reckons they will last.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
