man ive been missing out here. Gone a few weeks and everything happens. Nice power rockabilly, but thats alot of boost!
Old mate in NZ reckons he can rev out his twin cam 30's to 10k and reckons they will last.
there you go...
thats a engine....
i reckon that youtube video i posted of the vl at the track is turning about 9000 9500 rpm... thats music to my ears
Edited by den001
From the sound of it, i doubt that vl is running 272deg cams, or a 600 hp turbo, more like 2x700hp turbos and massive cams. The reason rockabilities sound like it does, is because at the beginning of the power run it is already making heaps of torque, so you just dont hear it ramp up as much. Also the VL is free revving as opposed to a set ramp rate. Cars on dyno dont tend to sound very powerful as the only thing that changes as they rev up is exhaust/intake noise
One word "Harmonics' :yes:
heard this term a lot and have limited my own 26/30 to 7k rpm with an ATI balancer BUT have yet to see or hear firm evidence of someone who has trashed an RB30 and can conclusively trace the cause to harmonics. not saying it an't so but can anyone provide evidence?
well guys mine went on the dyno as promised. here,s a you tube link, takes a while to load, done by the racing line where i had it mapped..
car ran brilliantly all morning till 1pm. did 20+ dyno runs , final run was @ 2.17 bar 652bhp@the fly 660lbs torque @ 5500rpm
went for dinner and unfortunately left the ign on. when we returned for some light on road mapping car is now knacked beyond a joke,,
change the ecu,cam sensor, ign amp, splitfires,plugs no joy.. wont rev and on the fuel map it stays the same but when you rev it up, and return to same piont on the map that had an afr of 13 now it reads 21? numbers are the same but afr has changed on its own?. lambda,s are turned off so not them. we puit some 4 bar map sensors on wonder if they have burned out?. will start again monday..bernie
I have been trying to find the full spec of the engine, this is what I found with a quick search, please ad anything I have left out.
cams are jun. 264/in 272/ex 9.7mm lift
tomei 1mm oversized buckets
shell v - power 98ron
bottom end i built all forged just the crank that’s std...
datalogit
Since you mentioned Datalogit assume it has a Power FC, must be a D-Jetro as I can’t see any AFM’s.
I would start by checking the diagnostics screen on the Datalogit (Power FC), it shows all of the sensor readings. Just look for one that looks strange, different or inconsistent. If I had to guess the problem I would say map sensors. But there are a number of other possibilities including temp sensors.
As for the power versus boost, the cam lift is a bit low for the power target, which I assume is ~750 bhp as that is the size of the turbo you have chosen. I have not seen any mention of head porting, I may have simply missed that post. But for that sort of power target it is pretty much a necessity. I didn’t see any mention of exhaust manifold or intercooler either. All of these items are restrictions, which simply increase the boost required to make less power. Remove the restrictions and the boost will go down and the power will go up.
As for the torque and horsepower being the same keep in mind the mathematics that;
BHP = Torque (in ft lbs ) at 5,250 rpm
Cheers
Gary
holy crap how much timing did you have to pull to run 2.17bar on 98ron fuel?
den001, its the compressor that determins airflow, so theoretically (in my mind) they should make the same power, allowing for restrictions of the exhaust housing which can be somewhat oversome by a big external gate
check out fullboost dvd 2 and you see logs of it revving to 11+......when you get a chance to see the log, maybe you can understand why it didnt last too long
...........restrictions, which simply increase the boost required to make less power. Remove the restrictions and the boost will go down and the power will go up.
finally...
ask kyle what his revs to...
cheers guys. gary..
some more details. today we removed the map sensors and fitted more new ones no different. also another set of plugs, no different.
be told by one of the uk tuners who has ahd a look at the graphs power is 691bhp @ the fly on the graph for 2.1 bar.
not sure of ign timing will ask.
also head has been ported polished and matched to the throttle bodies headers etc.
manifold is fromm extreme turbo manifolds, 44 mm tial wastegate, all ceramic coated. .
cp forges spool rods, acl bearings, n1 oil/water pumps. bottom end full balanced.
intercooler is hks drag 4" thick.
on the clip you can see the red light in car. thats my shift light set at 7k
thats it for now guys but please ask anything i will help if possible. bernie
just looking at my options as now having the forward facing plenum I need to redo my cooler pipes I also guess this means I can no longer run a plumb back BOV easily :D
Out of interest I have seen a Tial 50mm BOV for around $300 bucks new unused looks like a wicked bit of gear would this be the go for my final power goal of ~450 HP? I dont want anything with the huge trumpets that make em louder
Lowmount 3540 internal gate turbo with more than likely a ~600x300x100 cooler
If your goal is 450flywheel hp stick with the GT30.
If the goal is greater than 500hp then go with the GT35.
If its 450rwhp then definitely the GT35.
I am currently at ~450hp and don't run a bov. No bov really depends on your tuner; some say its fine some say oh no OMFG. I'm sticking with what my tuner suggests as they have never had a no bov related failure on their race car nor any customer cars over the years. Having been around VLT's in the past they don't run bov's never any issues with them.
hmmm interesting stuff had not even considered the no BOV option
to be honest 450 is my conservative idea as I went in my mates 400hp 33 last week and shite it was fast, the motor is a RIPS one so supposedly good up to 600ish but I think my driving skill (read: balls) need to grow before i attempt that
also from what I have heard the internal gate wont get me much further anyway?
The Int gate is fine providing you run the larger flapper. A GT35R with supporting mods (large cams, little port work, nice exh. manifold) will have you pushing close to 400rwkw.
The problem past 450-500hp at the fly is the std exhaust manifold not the wastegate setup.
good stuff! where how do i do the larger flapper?
I am on the hunt for a HKS cast lowmount manifold but will more than likely get it setup on the stock one to begin with
I have 275/40 Fedral SS595's on there at the moment hopefully they will go alright
would you say that the bigger housing (1.06) will be a little less violent than my mates .82 on the freeway?
Was speaking to Tony Rigoli tonight at WSID and he said they make their own sump adaptors but use 10mm sump bolt holes (same as RB26) not the factory size. He said with the extra weight of the sump/diff the standard RB30 holes aren't adequate.
Thoughts?
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
