I didnt think you had vvt in the 26 head?
Just out of interest have you spoken to Robbie at RIPS?
http://www.ripsltd.co.nz/
sori, vct/ yea a lil but hes a busy guy, if im not payin him i dnt think he want to help??
and its a huge toll call lol,,
thanks
go to the first page and download the pdf guide after you read that and if there are any specific questions to what your doing ask away!
the guide pretty much explains it all when it comes to what goes with what and how.
Read it carefully as i just put my motor in forgetting to do the RB25 sump mod now i gotta drop the sump off which is a bitch considering i just had the motor out on a stand!!!!!
RB26 does not have any form of VVT/VCT/VTEC
26 heads dont have vct - thats only the gheyass rb25's
my gheyass RB25 doesn't!
kool thanks, so wat do i need to block off etc?
ive neva realy been intrested in rb30s im realy stubbrn like that,, just realy been doin others,
im not going to spoon feed you, read the damn thread and pdf
It's so ghey that HKS decided to make one for the 26 and sell it for a small fortune :banana:
sif kill my bagging of the rb25 :(
one a side note, my billet girdles are ready :D
the one you see below is for the 4wd guys, it has the adapter encorporated in it. i can re-design it to make them for rwd rb30's, rwd rb26's & rwd rb20's. this also means my 4wd adapter plates are good to go aswell :D
sif kill my bagging of the rb25 :D
the one you see below is for the 4wd guys, it has the adapter encorporated in it. i can re-design it to make them for rwd rb30's, rwd rb26's & rwd rb20's. this also means my 4wd adapter plates are good to go aswell :banana:
so these adapters go over the top of the standard girdle?
correct. the std girdle/main caps get machined down to suit.
i initially looked at getting rid of the std cast caps, but when i looked at the caps where the bearings sit, they are not round (oval shaped) and they are slightly recessed - i dont have the funds to do r&d on 2+ motors to get that style of girdle correct, but i do have the funds to do r&d on this style of girdle
Wing it.. If you haven't got half a brain to work out the problems as you come across then its best you don't do the conversion. :banana:
Get the two motors in front of you and have a look. Its all quite simple.
yea i get that, i only have the head to look at, block is at machinests waiting on wat to do,
im just tryna cut down time,,,
sorry for asking this probably been asked and answered a few times but im not reading 306 pages.. so can someone please tell me the difference between a rb30 short block and long block.. and does it matter what one i use
Long motor includes bottom end and head and all internal parts but no accessories.
short motor is same as above minus the head, includes internal parts inside the block and sump.
It's obvious what you need for the det conversion.
sif kill my bagging of the rb25 :)
one a side note, my billet girdles are ready :P
the one you see below is for the 4wd guys, it has the adapter encorporated in it. i can re-design it to make them for rwd rb30's, rwd rb26's & rwd rb20's. this also means my 4wd adapter plates are good to go aswell :P
What are they worth?
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
