Hey guys i am looking at an RB25 head atm that has already been modified to suit the RB30 it has 820cc injectors and has made 680hp it has done 1500km and it has all been track time, now i do not have enough experience in RB25 and stuff to know whether that is a lot of K's or whether or not to just do my own head up because i do not want to buy it and have it shit itself a few hundred K's later, please no abusing me i just want some positive criticism cheers.
So you reckon it will be ok to buy >? I will save myself a couple of K if i do like i said is 1500km to much for a head that has been on track ?
itll be fine on the priviso that it hasnt been overheated
get it checked for warpage, flatness, valve seat sealing, valve guide clearance etc etc
This bit interests me, "r33 gts-t using an rb25 head & rb20 pwr steering pump". Why are you using an RB20 power steering pump? They are older and heavier and have no discernable advantage over the standard R33GTST power steering pump. Which is a straight bolt up.
Cheers
Gary
there was nothing wrong with my r33 pump but while the car was still in pieces we knew that the pump wasnt aligned & i could remember something in the pdf guide about r32's having some advantage over the r33's. i didnt relise it was the bracket not the pump. atm the pump is too far forward and needs to be moved back. Does anyone know if i put the r33 pump back on and use an r32 bracket if it'll line up any better? I'm using a ross gtr balancer btw
looks like i got my facts wrong. The car is fitted with a 32 bracket using my 33 pump. The ross balancer is a two piece but i cant space out the pwr steering belt ribs becaue of the design. the workshop are gonna try and press on the pwr steering pulley for me.
hey guys just getting my stuff balanced got told by the guy thats doing it that i need a smaller aftermarket harmonic balancer because of the high revs the engines pull the water pumps break anyone heard of this or is he just taking me for a ride, he has also never heard of one of these engines shiting an oil pump whats your thoughts on this?
Maddo, hard to actually decipher what you are saying but I'll try answer. A little punctuation makes it clearer.
The Water pumps do fail, sometimes without warning. One I saw recently had a chunk of something jam into the impeller so it must have been in the cooling system. The whole front of the housing exploded forward and slammed into the radiator.
The stock balancer is often good enough if you aren't going to try to rev to over 8000. After that I would advise a good HB.
The oil pumps will fail, for many reasons but usually due to having a short pump drive in some early series engines and banging off the rev limiter.
Change to a better oil pump than the RB30E unit as it was never designed to flow oil to a DOHC head and turbo. They will potentially give you oil pressure problems at idle... How do I know? I followed the advise of my engine builder and unfortunately kept the RB30E pump following his logic of "if it aint broke dont fix it..." bad move. Im now in the process of installing a brand new RB26DETT oil pump. $266 from Greenline.
From my research there is no difference between RB26 and RB25 oil pumps. Same part number in FAST and same flow rate. Don't get ripped of by paying for a "GTR" pump.
A pic of the different oil pumps. I will be completing a document soon on some oil pump info for the forum.
Maddo: If you plan to do track work, then i would also lean towards getting a ATI balancer. Yes it is under driven, but at high rpm you reduce the risk of damaging water, power steering and the alternator. Also you are going through the expense of building a new engine, why put on the std balancer that has 15yrs of wear and vibration :thumbsup:
Just my opinion and the reasons i bought my ATI balancer.
r_speedfreak_r: i can't understand why you'd even consider tampering with the ROSS balancer. They would be designed and balanced to perform the task and any modifications to such a vital component would be very risky. As i stated earlier, you should have no issues reseting the pulley on the p/steering pump.
Geoff: Nice work mate.
Hope QLD is treating you and your Mrs well. All the best.
Just a progress pic ;)
This is not the case in my copy of 'Fast'
RB25DET Part Numbers:
RB26DETT Part Numbers:
The Workshop Manual also states RB26DETT Oil pressure is slightly different:
Why the pressure for the RB26DETT is higher at idle but lower than the RB25DET at RPM I'm not sure, extra turbo, different relief valve spring?
I haven't got it running at the moment but I was looking in a completely different area with Funkymonkey. It was pretty descriptive.
Springs are linear so it would simply be because a 26 idles faster, but has less oil supply to the head. I've had them both apart, overlayed the gears and they were the same. I didn't have time to test the spring rates but they felt the same.
Those screen shots are from part's master.
You copy the part number into there and do a search and it will show you if that part is used on any other vehicle... Perhaps there are differences in the pump housing.
Note the attached pic, top RB26 pump, bottom N1:
Unfortunately I ant find a pic comparing RB26 vs RB25, but aleast this shows there are other differences apart from gear width.
Edited by MintR33
As I said, I could find no differences whatsoever. Not to say I didn't miss something in the housing, but nothing there makes any difference to the operation.
The N1 though is a common enough failure on drag cars banging on the rev limiter. The peaks in the much narrower area of the outer gear ring are typical stress concentrators. Add to that the material for the N1 pump gears has been hardness tested against the stock oil pump gears and was found to be much harder, therefore much more brittle. It is a compromised design which is unfortunate.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
