R31 auto cross member bolts up to r33 box (using r33 rubber mount). Obviously if your r31 was auto at one stage, like mine, the cross - member will bolt straight up to all 4 x studs. If it was originally manual you may have to mod it. Only bolts to 2 of the studs from memory?
g.
thanks guys will get onto it tomorrow.
also another quick question which i just remembered... any/all of you that are using the n1 oil pump what is generally your oil pressure readings?
When i first started up the motor it was maxed out at 8 and came down to about 6-7 (3/4) up. I'm not using a crank collar as suggested due to time and difficulty during assembly.
Readings with my N1 pump (no restrictors) are 100psi cold at idle. Warm is 10-20psi at idle (depending on oil temp) and ~20psi for every 1000rpm, so ~40psi @ 2000rpm, ~60psi @ 3000rpm, ~80psi @ 4000rpm and anything over that is pushing 100psi.
Hi guys n gals. been reading through almost all of the 246 pages of this thread and am just seeking some advice. im running a standard RB25 GTS-t engine (except for a race head gasket). with
740cc injectors
Greddy inlet plenum
Greddy 40mm piping top mount manifold with a T04 twin port flange
Turbonetics A65R turbo (good for around 700bhp)
HKS 4" straight through drag exhaust with a 5" back box
Q45 100mm throttle body
AEM ecu
Greddy BOV
13 row intercooler
race radiator
Os Gieken triple plate drag clutch
individual coil packs
probably more so will update when i check the spec list again.
what i would like is any advice on which RB30 block would be best for me. i like to use the power ofet and at full rev's :D so would a standard block suffice or do i need to go down the forged route, if so would the stock crank do or do i need to get it lightened/treated.
also do they handle NOs well or is there no need with the amount of torque they produce.
My Current engine doesnt start boosting properly until around 4000-4500rpm and is hitting the limiter at 7250rpm or so. i've read that the RB30 blocks dont like high revs but what would they handle on a regular basis.
ALL info much appreciated.
Regards, Thwish
All depends on how deep your pockets are mate.
If you have the money i would definitely go the forge route with the std crank and all other performance parts (arp bolts, acl bearing, etc, etc).
My engine has been tuned to 8000rpm but i keep the limiter at 7200rpm, just like the factory rb25det.
You can put NOS on all engines, just depends how good your tuner is.
Yup i agree, if you can afford it go forged. Use Arp bolts on your rods and decent bearings for the crank to be on the safe side. Factory cranks are pretty bulletproof and you could even get away with possibly shot peening the factory rods. With a strong bottom end you can keep upgrading the bolt on bits till it scares the s**t out of you daily lol.
I dont think nos is necessary with the increase in torque but again if its in your budget, why not try it out?
Make sure to post up on your progress as im in the middle of the same process!
hey guys hows it going? Hope things are all coming along nicely, been a while since i been on thought i drop a quick comment and update on my 30 build.
The gearbox crossmember is now in, have also made up a plate for the power steering pump motor is complete took the car for a drive down the road runs fairly rough, as soon as boost came on pretty sure it started leaning out hard!!! I was planning on running the motor in with all standard rb20det gear including turbo and ecu but dont think having the rb20det ecu is a good idea. I have gotten some bigger injectors, a fuel pressure reg and fuel pump.
The fuel pump is installed but not the other gear. Looking to either chip the ecu for the run in process or to go aftermarket unsure as funds are extremely low, but what do you guys think comparing a greddy e-manage ultimate to the new link g4 ecu??
thanks for the imput guys cant wait to finally start rolling again been too long!
p.s. does anyone know who does decently priced ecu's or may have second hand aftermarket ecu's avail. Preferably to be in N.Z but worst comes to worst will get something from aus.
Nistune will be your cheapest option.. I'm running a remap (pre-Nistune days) with a z32 afm and 550cc injectors, handles it fine. Will be going remap again with the new turbo, until I max out the z32 afm.
  • 1 month later...
Hey guys, yeah I'm another blerrie newby.
Umm, I've spent gawd knows how long glazing throught the sh$%loads of pages here and found it to be the best discussion on rb conversions out...
Good form people.
I know I drive a Bommodore, (I'm sory), but I have just started doin the bastard up.
Now I'm an apprentice 'Chanic working for my father,so I got a reasonably good idea what I'm doin however, I'm new to Jap stuff, all I know is Holden v8's to be honest.
Now I'm looking to pull around 500hp atw, (370 kw) one day, (a long way off I know), but as I'm just starting where should I start?
Initially I'm gonna acid dip the block, balance the stock internals.
I wanna chuck a 26 head on it, with the VCT, that doesn't worry me in the slightest.
Now I need to drill and tap the rb30 block to accept the larger head studs?
What is the best idea for inlet / exhaust / cheap starter option?
I mean eventually I'll throw some good Tomei gear down the 30 block, port and polish the 26 head and go to about 25 pound on the boost guage... What should I be looking to do to get that far?
Money are an issue of course, so any price guides would be much appreciated.
As for time, well I have got a second RB30 al;ready in the car, so I have THIS one on a stand for the rebuild...
I got no idea on computer gear, dynoing and whatnot, any advice?
And before I go, (Cos I know you'd be sick of a prick like me),
I'm gonna convert the VLK to manual, the cursed 5sp, I'm guessing other than a decent clutch and light flywheel, it should be able to cope with a gentle right foot until I can drop a r34 manual in it???
Sorry for being a long winded bastard, but I wanna do it right!
Cheers
RB26 doesnt have VCT
yes you will need to drill and tap the block for the larger head studs.
keep the standard RB26 inlet/throttles they work fine, exhaust depends on what turbo setup you are using.
tomei dont make RB30 pistons/rods.
Aha... I thought that Tomei did... Just shows how little I know.
Which ones had VCT??? I was told that in the whole RB range it was only the 30 and 25 NEO that didn't?
Oh well.
Nonetheless, cheers.
im looking at a 26/30 upgrade for my r33 gtst.... well gettin a rb30e block tomoz... are there any problems i will run into with this head and my pfc?? any TPS or CAS problems??
i assume the easiest way to do fuel is to get the 26rail & injectors to suit, any problems with running them on my 33gtst PFC???
I just did a series one rb25 head swap on my new forged rb30 engine with mls head gasket and cannot find out wtf is wrong with it.
Is there anything needed to be done on the head or block such as block up any oil galleries?
Because i get coolant mixing with oil and theres a big leak somewhere when i put the radiator pressure tester you can hear its making a squishing sound so it a big hole some where.
just a quick question!i am building a rb25/30 in a r33!looking to get a big turbo on the build!will a gt35/30 turbo be too big on a low mount manifold or do i need high mount,prefer to get low mount with big turbo,looking for about 450-500hp at the wheels!suggestions on turbos please guys!
a garrett GT35R 0.82 exhaust housing is the perfect choice for that hp target. you 'could' mount it on a low mount manifold, however you are better off using a properly made hi-mount manifold like a 6boost to gain the optimium performance. Also hi-mounts are 10x easier to work on :blush:
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
