yes i would agree that with a 25 head with stock cams it will start to drop power past those revs casue a stock 25 is only setup to rev to 7 in the factory so the cams will be optimisesd for up to this region, the ability for an engine to make revs in the top end is all down to breathing and the cam specs have a lot to do with this!!!!! there is no point reving it if your making no power but as this wasnt stated i gave a rough indicatory remark to ehat the engine is capable of reving to!!!
Hi Guys,
quick question.. i am looking for a turbo for an RB30DE with RB25DE head (conversion is in progress)
would a T04 turbo be okay? i am looking for around 250rwkw
I found this one on ebay, would it be suitable? http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=ADME:B:DS:AU:6
Thanks guys, brilliant thread, fingers crossed i get through this conversion :) (which is step 1, step 2 is getting it into our Datsun 240K ;))
Joel , have enquired about the Power FC and was told the following . Price varies from $1200 - $1500 depending on the application . The RB20DET R32 version is not common and more expensive as not many were made . I understand that you used one and mat may have one for sale . can you breifly tell me of your experiences with it . Please excuse typo's as my delete key is stuffed .
Thanks joel and all A .
I have an R32 GTST Power FC, had it for over 3 years, used the Commander for the first year and a half to tune it and a Datalogit for the last few months. It was on the RB20DET for the first year or so (ended up at 225 rwkw) then we put the RB30DET in it (RB30E bottom end with RB26 top end) and it handles the 400+rwkw just fine. Our race team dyno tuner had never seen a Power FC before, reckoned it wouldn't be as good as the Motec's we usually use. Now he is converted, mostly because they are so easy, they work straight out of the box, all the tricky stuff is done. Plug it in (5 minutes) and onto the dyno, where he just has to tune it for power. The Datalogit is worth it if you do lots of tuning, then more mods, then more tuning etc. I find the Commander very handy, replaces quite a few gauges and great for diagnostics.
I didn't worry about how much the R32 GTST Power FC cost, because I knew I could get my money if I ever sold it. They don't loose much, cause they are rare. With the Commander it cost me $1,400, I reckon I will get that back, so it only costs me bank interest to keep the PFC, that's $1400 X 4.99% = $1.35 per week.
I reckon that's a bargain. :(
Question for SK , can R32/33 GTR six throttle inlet system be fitted to R32 RB25DE head . Is the difference it makes worth the $1000 for a road car . Can it be made to work with RB20DET loom and sensors or the R33 single turbo loom and sensors .
Thanks A .
Thanks  A .
No, bolt pattern is different, water jackets in different places. I have answered this question so many times, it's like Groundhog Day. Nissan didn't want people sticking RB26 stuff on RB25's, so they made it as hard as they could. They wanted to sell GTR's after all. :(
SK thanks for the above reply , do you know where I could buy one in Sydney . You've also answered another question - can it run the GTR inlet system . Was there any mixing and matching of sensors ?
Thanks again  Adrian .
I bought my PFC off the forum. I used ALL of the R32 GTST sensors and the R32 GTST wiring harness. I carefully removed them, one by one, off the RB20DET and put them onto the RB30DET, that way I knew everything worked. The only thing I changed was the AFM, we used a Q45 AFM, the RB20/25 AFM wouldn't handle the airflow. The RB20DET already had 565 cc injectors, they went straight into the GTR fuel rail and inlet manifold. I just upped the fuel pressure with a Nismo adj FPR, the Bosch 044 handles it easily. I even used the RB20DET ignitor and coils.
I put the old RB20DET back in a while back while we built a new RB31DET, which is just about ready to go in. (Similar max power, but higher average power). I will follow the same simple rules, use EVERYTHING (from the RB20DET) that plugged into the standard wiring harness. Change as little as is absolutely necessary.
Hope that answered your questions :(
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
