HI EVERY ONE MY R32 GTR SPAN A BIG END NUMBER 1 AND THE CRANK IS 7 THOU WARPED THE MACHINE SHOP CAN FIX.SHOULD I GET MINE FIXED AND USE IT?
CAR IS A STREET CAR AND OFTEN GIVEN BIG SQUARTS.I AM REBUILDING MOTOR WITH FORGED PISTONS AND RODS,ALL NISSAN GASGETS ETC.THE ONLY THING I NEED TO KNOW WILL MY REPAIRED CRANK BE OK?
https://www.sau.com.au/forums/topic/154269-r32gtr-crank/
Mate, turn off the caps lock.
Specified GTR crank runout is 2 thou (max), so 7 thou is a bit much. Straightening a crank is a very common procedure, and, no, it doesn't affect the strength of the crank (assuming they know what they're doing).
Edited by SteveL
https://www.sau.com.au/forums/topic/154269-r32gtr-crank/#findComment-2869143
sorry about caps lock,nissan sell only 1 crank now and i am told it is the better unit.but a price of 1100.00 i was looking at another option.the second machine shop can regrind 20 thou and they asure me it will be fine and crack check the crank.
https://www.sau.com.au/forums/topic/154269-r32gtr-crank/#findComment-2871883
never machine a nissan crank much further than 10 thou as the side clearances will really run out, you need to radius then you will start going through the factory nitrating and you will have alot of probs. Generally I would say its ok but what bearing you going to get for 7 thou, you will find you will need to run to 10 more than likely. As stated good idea to fit a collar and a bigger oil pump, buy the time you do all this at a guess your machining costs are going to be up around $600, probs a better option to get a new one, but hey its up to you can be done.
https://www.sau.com.au/forums/topic/154269-r32gtr-crank/#findComment-2871902
You probably could re-nitride it, but this all adds to cost - and makes a new one seem even more reasonable if your going to spend that much on fixing the old one.
The old crank has done what? 100 000kms? Im sure a new one looks much more attractive.
Cheers
Sumo
https://www.sau.com.au/forums/topic/154269-r32gtr-crank/#findComment-2877662
nitriding is a very tricky process, especially to achieve the results the standard factory nitriding has achieved, its a waste of time and you probably ruin 1 or 2 cranks to get the process right, would you want to run the risk???? I am talking from experience, and anyway the crank wont need this if under 10 thou which it is!!!
https://www.sau.com.au/forums/topic/154269-r32gtr-crank/#findComment-2878869
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
