nice article but without the wheel sizes it's not proving anything.
<quote>
well on 1.7 bar with our gt3040 .82 we made 375rwkws and 365rwkws on 1.5. After 1.5 it was starting to blow hot air and power wasnt increasing much as you can see.
</quote>
This sounds promising!
whats cams did you have?
ill br running 272,10.3's so i dont really want to go the 3540 (1.06)
  • Replies 87
I think we should call mythbusters! Nah very nice 450, im guessing a fairly decent size a/r 1.06 above mind you lowered compression highlift cams, but does sound bit unreasonable from the guage of the other posts, yet does not state what fuel is run to achieve that power, C16?
Good you do that
Cause telling people they can make 450rwkw off a GT35/20psi on PULP with just 260 cams/no porting is a joke and would grossly mid-lead people
We'd better see a MPH well into the 135 range (140 possibly i think).
You'd also better send a letter to Garrett, they'd be interested to know about it aswell im sure.
Couldn't agree less.
My mate ran 9.95@136-138mph (VL) with 1.6/7 60'ft marks making 367rwkw
On 9 or 10inch slicks with front runners.
So if someone were to run with 450rwkw and full slicks, you'd expect nothing
under 140mph to justify the claimed power output.
Hell...with that much power you would expect a 10sec pass on re-treads... :D
However, if the stated power is correct on such little boost pressure...that person would probably put GARRETT out of business if he could supply Gt3540's that may produce that much power on such little boost.
GARRET would probably discontinue production of the GT45's
Yep...
Im not seeing it on Plup and 19psi as R31Nismoid said the trap speed is far to low, as mine are 130mph and im well short of 450rwkw...
Now im not sayign that he does not have 450rwkw im just syaing there is something missing here like methnol or funny gas...
Just to sow a few seeds of doubt ...
A while back I came across a few pics of what the Americans sometimes call a "GT35R T4" , this is basically a std issue GT3582R cartridge and comp cover but its turbine lives in a reprofiled TO4 turbine housing . I'll have a look and see if the pics are on this computer .
What Arnie said .
Edited by discopotato03
a guy here in NZ has a .82 gt3540r running 450rwkws on an rb25det (stock internals to)
Just to upset you all further, lol, we had a car make 477rwkw on our dyno dynamics dyno, often accused of reading too low :).... yeah right :D
rb25 head rb30 bottom end, head majorly modified for flow with epoxyed ports and big cams etc etc running a 3540 with the 1.06 exh housing and all supporting mods running a haltech ECU. The car is an absolute weapon! Not sure if it was on PULP but can check.
Will also get the dyno graph to show you all.
Couldn't believe my eyes actually :( but "hey" I was there and thats what the dyno said :)
Fuel usage logged on the haltech at the 11.5:1 AFR matched up with calculated power figures too. Thats always a good guide to use. The laws of physics don't change after a good arguement eh?
Mike
How does that upset anyone?
Its a different car, different setup, and unknown fuel/boost again.
Shall i just get out a ball of string? Its about as accurate as your information... or should i say, lack there of :)
Pics not on this computer .
The rotary turbo people say that using a T4 turbine housing moves the whole power range upwards , depending of course on housing A/R . Just my 2c worth I always thought the GT3582R had a little too large a compressor trim or not enough turbine depending on your point of view . Using larger than the biggest factory 1.06 A/R turbine housing will reduce turbine inlet pressure but it may be trying to tell us that the turbine is running out of legs . It makes me wonder why Garrett didn't make something like a TO4Z but with the GT40 82mm compressor instead - TO4 40R ?
Cheers .
The owner of a local tuning workshop owns an XR6T. He told me to push over 400rwkw they enlarge the internal gate and drop on a T66 (?) comp wheel with a .7 comp cover leaving the turbine wheel standard. IF they want to go all out I think he said they ?back cut? the turbine wheel.
That would be the GT35R with the TO4R compressor swap . In the US they're called GT3567R though by Garretts own system it would be called GT3584R . Many don't agree but I think its a case of fitting a larger size AND trim compressor to a turbo thats borderline on turbine size to start with . If I really wanted that compressor I'd buy a TO4Z because thats what they get standard but with a larger diametre smaller trim (76 vs 84) TO4 P turbine . They also have the larger diametre turbine shaft and bearing cartridge and don't tend to bend this shaft like the GT3567R can at times . The TO4Z is a Garrett factory tested combination where the GT3567R is a "wildcat" or aftermarket hybrid .
Peaceables .
Well according to Garretts own compressor and turbine graphs ~ 65 lbs of air at 60% efficiency for the compressor and ~32 lbs/min corrected exhaust gas flow at ~ 2.4 - 2.5 pressure ratio or ~22 psi gauge pressure .
At the bleeding edge I guess that means if you assume 11 Hp per pound of air 65 x 11 = 715 at approx 2.5 pressure ratio (22 psi - gauge) .
At the sort of gas speeds to take this turbo to the limit you possibly need to consider T4 flanged turbine housings so that the gas speed into the housing is not high enough to be forming a restriction or pressure rise .
Found the pics of the T4 housing on GT3582R . ATP turbo have had a couple made as well and the pics are on their site .
Cheers .
then why the f**k is my motor only making 307awkw on 20PSI thru a to4z .84 split rear?????????
gay i should be up heaps. could it be the 230000k old motor and stock everything inside?
That is correct :)
You need cams/cam gear, little bit of a tidy up of the head too.
On 20psi going by most others, you should be up above 350rwkw easily
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
