Street Racing Story.. is it on Today Tonight or A Current Affair?
Had a Guy at work say it was going to be on A Current Affair?
Anyone able to confirm 100% which one it is supposed to be on as I'm curious to watch this story..
And Both websites for the programs don't say anything.. Typical.. Never tell you anything just to get you watching ALL week :)
Cheers !
it was channel 7...
seen the ad about 5 times...
Not once have they said what day though.
BUT
the last add i saw said it was going to be on the actual NEWS at 6pm, I dunno what the story is.
pft if one jumps on it they all jump on it.. assholes..
thing is they'll show it as guys doing burnouts and things like its so "dangerous" and people will think its like that because they've got it drummed into their heads under every circumstance will speed kill (it doesn't, or most of us wouldn't be hear speaking now would we).. and yet, when i was at calder a few weeks ago in the burnout comp, cars were doing burnouts with no kind of barrier metre or two from the crowd. What is the difference? not much, just one has officials around, and one doesn't.. big deal.
Thats probably another reason actually.. people get hurt.. costs the government money in TAC cover.
We should all chip in and buy a carpark somewhere :D then its private property.. not much they can do then.
It really doesn't matter what channel/time it is on... I'll give you the SCOOP!
You'll see a couple of older-model falcadores in gutters and around trees, police casing a few cars, falcadores doing burnouts and it'll all get blamed on young drivers and imported cars!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
