Any of you guys seen 2MUCHKW drivin around the city.. xr6t
i seen it the other nite and i seen the plates and went puft, rite oh.. i kept cruisin then he pulls up next to me doin about 60-70 and then drops it back to 2nd and starts spoolin and spinnin..
my jaw dropped and i was like get f**ked that sounded f**kin mint!!
he did this multiple times in front of me, was like watchin a movie but bein in it! was awse.
so all you guys that are givin em shit.. they might be shit, but this thing f**kin rocked! i'm not much of the ford fan, but i dont mind these aye! especially this one! so yeh i guess he kinda lives upto the name of the plates, which is good to see, instead of some loser puttin it on a stocker.
they do sound mint!
there is 1 in town that just has a flash tune ecu, bigger injectors and exhaust and a touch more boost that put down 397hp on a hot day at the local dyno comp last year.
another mate of mine has a built xr6t that supposedly had about 440hp. had time slips for 11 second passes (it also had polished rocker cover and a few other things but only stock turbo). on the highway at 120kmh if he pinned it when it dropped back to third the traction control would kick in. he wasn't game enough to turn the traction control off.
  • Replies 73
Ummmmmm have you had a look at the recent class action suit against Toyota?
Yet again Toyota has been keeping problems under wraps, paying off irate customers outside of court and outside of media scrutiny.
Problem was one of these Toyota owner has gone out and exposed Toyota’s engine problems and their under the table hush money.
RESULT? Toyota was forced to compensate owners of Lexus and Toyota vehicles. The problem affects 3.5 million Toyota and Lexus vehicles with model years between 1997 and 2002. This sludge build-up problem according to experts was the result of bad engine design and can cause engines to die (requiring total engine replacements). This problem will cost Toyota Billions of dollars to rectify.
dude seriously read about the 2jz and 1jz... i think thats what the bloke was on about anyway...
ford isn't the only aussie company to have trouble with turbo 6s. i was talking to a mechanic about this yesterday and he said that the first model vl turbo had heaps of dramas.
also here's some recent nissan recalls.
2006 NISSAN SENTRA and ALTIMA - CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.5L ENGINES MAY EXPERIENCE EXCESSIVE ENGINE OIL CONSUMPTION AS A RESULT OF IMPROPER PERFORMANCE OF THE PISTON RINGS
2006 NISSAN MAXIMA - ON CERTAIN VEHICLES, THE REAR SUBFRAME MAY HAVE BEEN MANUFACTURED INCORRECTLY, WHICH COULD RESULT IN A CRACK IN A BRACKET WHICH HOLDS PART OF THE REAR SUSPENSION.
Defect Consequence:
IF THE BRACKET IS CRACKED, THE STABILITY OF THE VEHICLE MAY BE AFFECTED UNDER SEVERE DRIVING CONDITIONS. THIS COULD LEAD TO A LOSS OF CONTROL OF THE VEHICLE WHICH COULD RESULT IN A CRASH.
just do a search on nissan recalls. there's heaps.
this was originally a little inside info what could be a major problem it has been turned into a manufactures war it was about fords now we are hearing bout this car and that car and oh this car did this and didnt do that the facts are there they dont lie...
Even though i started the thread i am glad they crap themselves as it keeps me in a job, it's fun pulling out and stripping engines (smells rad).
I have seen first hand the problems with these vehicles but so far there have been no problems, recalls or service letters on the turbo focus. maybe volvo got it right.
that xr6t with the plates 2muchkw is putting down around 500rwkw
there is an article on it in the latest perth street car mag
its had:
new rods, forgies, balanced standard crank, ported head
Nizpro intake manifold and front mount
experimental aftermarket cams (custom grinds, these apparently might now come off the shelf)
now just put on:
850HP garret turb
custom exhaust manifold
massive 1600HP n/a aeromotive eliminator fuel pump and 80pound injectors
result:
507.7rwkw or 680rwhp
the reason its such a beast is beacause of the near flat torque line
on 17psi (max hp at 24psi) the torque ranged from 600-750nm from 3000-6000rpm = tyres melting with part throttle in 4th gear
so there u go
Edited by 342Four
Lets look at these stats
how many xr turbo's made in 1 year, 100 000. Lets say 1000 of those blow up, break, fall apart before 50k. Thats what 1%. Im happy with those figures.
No offence dude, but you're posting that you are happy with reliability figures you just made up?
PS. Last year Ford sold 43,000 Falcons of all models and variants.
http://www.drive.com.au/Editorial/ArticleD...ArticleId=22464
, please
Edited by PHATR32
yeah what like? all i can think of is radiator lower than the head...people never beld the cooling system properly therfore cracked heads.
oh that and they are a crap car....(engine is fine but)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
