  • Replies 46
Posted Images
We have a 25 with as much or more mods that makes only 295rwhp@18psi even with a GT35 turbo ,much less than a stocker will make with the same turbo.Cams were so far out that it only made about 130psi cyl pressures even tho the block was shaved so far that the pistons were touching the head.There is a lot of shops trading in Australia with no idea so be very carefull as this guy payed for a race engine.The 295rwhp was a very small peak at about 6500rpm with less power than a stock rb everywere else and less torque than a basic RB20. Best thing to do is get someone to dial cams in and retune.
lol $40,000k? for only 360rwhp?
HAHAHAHAH your mate has been owned big time..... does he not know how to do anything himself?
If he had 40,000k to spend on an engine he should of bought a twin turbo jza80 supra and spent the money to have an 800hp monster but each to his own i guess....
I have spent like 2k on my car for engine mods and am making in the vicinity of 260rwhp.
I know that to go up i must get a new turbo, computer etc but i would still want to come out f*cking short of 40,000.....
I hope that 40,000 inlcudes bodykits, wheels etc etc....
Yeah well thats what im saying $40,000 for only 360rwhp is a joke.
And no it does not include bodykit, wheels etc.
my rb25det is making 274 rwkws at 17psi and 346rwkws on 24psi and im running gt3040 600hp garrett,spent half the money you have and thought that is alot! post up your dyno sheet, your power curve might give an insight to what is robbing you of power!
This is the best he has got out of it 390 rwhp.
But current tuner only got 360 rwhp.
It should be more for the money spent.
So where did the 40k go? All on red?
The parts you listed dont even come to 15k mate im afraid to tell you even with assembly of the motor
Unless your mate paid $3000 per rod, and $3000 per piston.
So its either your telling stories, or your mate is
The parts listed are a fair cry from 40k. Doesnt even come close to knocking over 20k
I'd say the figure of 40k was including things like rims, suspension, body kits etc etc etc etc.
But as cubes said (i did not have the time earlier), they are a LOT of things missing.
Even the turbo spec iteself.
All thats been listed is about 1/2, and its not enough detail for the items that are there, let alone whats missing
Maybe the FMIC has pressure drop, maybe the head gasket a whopper and its dropped the comp ratio substancially meaning mroe boost would be required.
Subzero, get your mate to signup and give the FULL detail and history, no-one can really help unless there is basically a thesis on what parts are there, whats been done, whats been tried.
What has not been tried etc etc. Its a lot more detailed that just listing some of the parts that have been used.
Simply saying a car isnt performing and asking for answers is like asking how long is a piece of string.
Ps. im moving this to Forced Induction.
Ok i have the reciepts right in front of me.
Areas pistons
rods
meatal head gasket
clean parts light polish
service and cc head
bottom end bored and honed
blue print engine and balance
N1 oil pump and bearing kit.
Arp stud kit
FMIC
machine rotors and new pads
Labour
$9850
exedy clutch
gear oil
turbo housing
micro tech and hand set
oil and filter
Irridium plugs
msd dis 4
coil pack
leads
labour to fit all of above and dyno time
$9125
Gt 35 -40 turbo
custom plenum and throttle body
custom fuel rail
injectors.
Dump pipe
3"exhaust and 3.5 high flow cat.
custom exhaust manifold
oil catch can and braided lines
radiator
Labour and dyno time.
$15000
total so far $33,975
Going by the reciepts he did it in stages i would say that would cost a shit load in labour and dyno time
going back and forwards.
Edited by subzeroR33
Areas pistons
rods
meatal head gasket
service and cc head
Arp stud kit
FMIC
Labour
$9850
exedy clutch
gear oil
turbo housing
oil and filter
Irridium plugs
msd dis 4
coil pack
leads
$9125
Gt 35 -40 turbo
custom fuel rail
injectors.
Dump pipe
radiator
$15000
See, now we are getting somewhere. :D
Your finally listing all the parts that we've asked! Now expect a longer post qith lost of questions :yes:
Now we just need listed whats occured thus far with the tuner...
Have they been asked about it?
What was thier response on it all?
Have they worked with Microtechs in the past?
Are they an expirienced workshop?
What was the reason for not installing cams?
Just while we are here, in "section 2 & 3" that you listed your mate was ripped off something severe. :sorcerer:
More-so section 3 which i'll post here just to put things into perspective for you.
Section 3's total for me came to ~$9,800 not $15,000.
Gt 35 -40 turbo - $1750
custom plenum and throttle body - $1700 (v.rough)
custom fuel rail - $600
injectors - $850
Dump pipe - $250
3"exhaust and 3.5 high flow cat - $1100
custom exhaust manifold - $1500
oil catch can and braided lines - $450
radiator - $600
Labour and dyno time - $1000
Now, if he did pay $15,000 for all of that, it raises an instant question... who he is getting the parts from?
And take the over pricing in section 2 into account (roughtly 3k).
If it was the workshop in question, then i would be instantly changing as that pricing is very very incorrect.
So your mate has, just in parts, forked out well over (in my opinion) well over $8,000 more than he should have.
You should note sprys dyno used to read very very low. he has had it calibrated within the las 4-5months but 12moths ago i made 460whp at PITS then went straight (same day) onto a brand new shootout mode dyno and put down 530 in my gtr...
See, now we are getting somewhere. :mellow:
Your finally listing all the parts that we've asked! Now expect a longer post qith lost of questions :)
Gt 35 -40 turbo - $1750 he paid$3600
custom plenum and throttle body - $1700 (v.rough) he paid $2100
custom fuel rail - $600 he paid $1000
injectors - $850 ????
Dump pipe - $250
custom exhaust manifold - $1500 he paid $2300
radiator - $600
Labour and dyno time - $1000 he paid $1650
Ok the tuner mainly works with motec and bagged microtech not good but have been going there for years and didnt trust anyone else.
When we got the results of the tune 360rwhp, he said that the map sensor was not up to the high psi that it was running with the microtech.
so he reduced the psi 22 down to 19.
No hasnt had much experience on microtech.
Yes experienced workshop.
Didnt put cams in, ran out of the $$$$$$ as you can see it had already cost a shit load, and they said it was making good power without them???
So whats the problem with the power curve, is that bad the way it drops off.
And thanks for everyones input so far its been a big help.
And just to clear things up.
1) All mechanical work was down in a experienced workshop.
2) The dyno sheet shown above is done at pits with the result of 390rwhp, no mechanical work was done there only the tune.
3) The current tuner has detuned it to 360rwhp and said it was the map sensors in the microtech. He had to reduce the psi as it used to miss and breakdown in high boost.
Yeah that is a big difference which one is accurate.
Well if pits was 390rwhp and the current tuner was 360rwhp his must be really low LOL. So that might be in our favour. :mellow:
get some cams. after spending $40K on this thing another $1500 or so (cams and installation) would be well worthwhile. then go to somone who really knows the microtech product as it sounds like the current tuner is perhaps a little un willing to work through any problems with the current ecu.
btw, pls come clean! I'm assuming this is your car. just like the time I went to the doctor to talk about my mates case of c0ck rot. lol.
When i was at Chasers motorworks i was talking to the mechanic there and they were in the middle of building a motor for a r32 gtr, the motor pulled out and put back in including forged pistions and all that normal shit people do, including 2 gt2861's dyno and everything cost around 10k, when they tuned it they got 265awkw on 1 bar.. and probably get more out of it..
This other dude i know that had this s15, under 20k on every mod he done from stock incl clutch and ecu and tune and full rebuild forgies and shit seen him make 300rwkw.. For $40k i'd want a full blown race car lol
Whats the 'new' rear housing?
.82? What was the old rear housing? Do you have dyno chart for that also?
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
