  • Replies 80
Posted Images
lol, yeah Im after at the very Least a tune at 1bar (14.7 psi?), not mucking around on 12psi when Ive got a highflowed turbo and all the support gear, and my stnd turbo was previously tuned at 12psi anyways (160awkw).
Have a Nismo fuel pressure regultor, so all should be good. Have hit the dreaded R&R at around 14psi untuned, whereas 13.5psi the engine pulls pretty hard. I think there is enough bolted on now for a good well-rehearsed tuner to tune around the stnd ecu to get the 1bar happening.
Id like to reach the 200awkw mark, but seeing this is a rwd dyno, I guess Id be disappointed if I walked out with a dyno sheet showing under 220rwkw. I feel 240rwkw should be the goal, and with my mods it should be achievable.
my engine shows that it is under 90,000kms old, never been compression tested. have a adj. exhaust cam gear wheel but wont have it put on at this stage (finances, plus I dont have the tools to DIY), got lots of other parts installed but here are the engine goodies:
New fuel filter & oil filter with Penrite 10w-50w oil
Davies Craig automatic transmission oil cooler upgrade kit
Bosch 040 fuel pump with direct battery feed at 13.8volts
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system
3inch Catco high flow catalytic converter
3inch cat-back mild steel exhaust system with quiet muffler
K&N pod filter, freshly cleaned
Cold Air Induction box with direct air feed
Radiator cold air guide
Hybrid dual stage Electronic Boost Controller
Apexi 'hybrid' front mount intercooler with custom return air feed pipe kit
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Slide Performance bush bearing highflowed R33 turbocharger rated to 250rwkw @ 1 bar
Hey, dont knock the turbo until you've at least sampled it. Slide makes a pretty awesome piece of kit - for the budget price of the item.
yeah Deluxe, I was thinking 230-240rwkw. With a good tuner Id like to think a bit of power can be pulled, even with only the 2 piggybacks in lieu of a proper ECU. Simply cant afford a stand alone ECU currently, anyways. Also, the stnd injectors can flow around 218awkw at 100% duty cycle. So with some management of the FPR and the SAFC/SITC Im sure a decent tune can be sorted for me.
heres hoping !!
heres hoping !!
sorry fella i wasnt knocking it. just trying to lighten the mood.
Boost worx is even better, now the boys have an A/C unit 'mounted' in the overhead framework :domokun:
I spent a fair part of both Sat' and Sun' down at the workshop working on the R33, in the prime location... right under the A/C outlet *aaaahhhh*
Boost worx is even better, now the boys have an A/C unit 'mounted' in the overhead framework :)
Yeh and that installation was fantastic....... :laugh::laugh: Couldnt belive my eyes :huh:
Good to finally meet you too mate! :)
G'day Joel,
Getting pretty close now mate. It's running. We've still got a dozen or so smaller tasks to complete (mostly asthetic) and we 'may' end up having to swap the exhaust housing & wheel over if it shows in tuning that it's too large.
See attached pic, taken 2wks ago.
Ha-ha yeah mate that A/C install is a classic! But it works. Yeah good to meet you too. The wheels on your 33 look awesome!
A further update on my latest tune (first post) - I'm actually back in Adelaide now, several factors told us that Adelaide will always be home to us....
I've just driven to brisbane almost 2 weeks ago and drove back to adelaide middle of this week, and what I found was that the car was pinging a little on the 96 octane fuel when doing a bit of spirited overtaking :)
So had to take it a bit careful whilst running on the (crap) standard premium fuels. This side of Parkes there are no places I'm aware of that have 98 octane fuel so we had 2 full tanks of 96 octane until we finally got to refuel with the good stuff. It would only ping when I stomped the foot to the floor to drop it back to 2nd, so boost would hit 12psi straight away and the car would launch pretty hard (even at that speed), but on one occasion I did hear a touch of pinging so we took it a bit easier after that. So even then it wasn't pinging heaps, just on one isolated occasion...
Its not Shaun's fault. It was a very hot day when I had it tuned anyway so it was already tuned safe for hot weather and its hard to allow for lower octane fuel without sacrificing too much usable performance. Plus he did mention that I should only be cruising at under 3000rpm when on lower octane fuel so therefore there shouldn't be a problem.
On 98 octane fuel its had no trouble whatsoever, not here in ~40deg heat and not in brisbane with 35ish deg and 3 million% humidity (well close enough).
So just a word of caution to anyone driving in the country - go carefully on the 96 octane fuels. IMO there is more difference between them and BP ultimate 98 than just the octane rating.
And for the record it did run well on 96 octane fuel without any trouble when cruising at 110 and when accelerating normally up to 110.
All in all it handled the 2000km trip each way very very nicely, and still runs like a dream.
All the best with the tune next week. I guarantee you'll be happy with Shaun's work and definitely with the price.
You're gonna have one VERY quick stagea... :)
Yeh cheers mate....... But i'll take your engine bay over my wheels anyday :(
Sounds killa too!
whatsisname :
Your engine bay looks rather tidy.
I will be taking my car to Shaun once its all back and running smoothly. I need to sort out the fuel econnomy ( or lack of) and a bit of more loving for my engine.
It doesnt help having shit coil packs in missing so much that the raw fuel just goes out the exhaust. 127km at 1/2 tank. This is from filling it up on sat morning and driving it maybe 4 times since then.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
