Hey all
how much boost and how many kws of power can a rb25det take (obviously depending on driving style, but generally...)?
my rb is pushing 230-240 at the wheels on 20psi (very rarely on max boost) im just worried the internals are gonna kark it...
Should i be heaps concerned about making more then 250 on stock internals or can the pistons n stuff take more?
Cheers
Edited by DjeMz
https://www.sau.com.au/forums/topic/155907-how-much-power-is-tooooo-much/
  • Replies 56
As above
There are many topics on this.
Its each to their own. You can make over 300rwkw, but most people dont have it that way daily, and to my knowledge the others have have not, all died at some point
i have a mate who has a rb25 runnin 280rwkw... bigger turbo blah blah but yeah its not showing any signs of dying any time soon...
Theres a guy here in the states who had an rb25 with 595 rwhp in his Z car.
Keyword *had* the internals held up for a while.. But man, thats pushing it... Thats a ton of horsepower even WITH a good tune.
yeh mine made 254 and went bang after 3 months but that was due to bad tuning aswell but....i know theres a dude here in sa making over 300 on the stock internals and has done for a while
Over 300rwkw on stock internals?! That must be an amazingly good tune...
hahahha
well the 25 is in a s13 silvia... and std computer, std injectors.. standard everything except for GTR pump... lol
i didnt believe it untill i seen the dyno read out...
neways he is building another motor with gtr rods n pistions...
neways he knows what he wants :P
I had 350hp for ages before a hole ended up in piston 1, but that was down to either injector failure or a crank angle sensor problem I had. A mate has 410hp on his & thats still going, but it would probably go if he kept it on full boost for a while.
impressive gt-passage.
so in theory a bigger turbo with less boost is safer than a smaller turbo with more psi making the same power? sure it will be a bit laggier but will be safer for standard internaled rb25? is this a valid theory? common knowledge?
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
