  • Replies 838
Posted Images
currently playing...
MGS4 - so far the best game i've ever played.... but i'm a tad bias as i love the first 3 metal gear solid games.
Age of conan - got the SE when it came into our warehouse just cos we had a spare one, never liked mmo's (apart from PSO on dreamcast and gcn) but am enjoying it so far, hope to stick with it and learn to play correctly.
Tetris - NDS version very good port not as good as my old pc one, but fun having high score comps with my brothers.
I'm currently switching back and forth between MGS4 and GTA4... had MGS4 since Thursday and my girlfriend got me GTA4 yesterday for my birthday. I finished MGS4 yesterday and started going over a second time today as well as started playing GTA4 today too :P
currently playing
- gta iv starting to get boring, really isn't all that special.
- rock band - downloaded some new songs so thats keeping me entertained.
thats about it really, i've bought the new alone in the dark but want to finish gta before i start it, done about 53% of gta so should be getting close to the end of the story.
I have been playing Battlefield bad company, made the rank of colonel in less than a week :P Its taken me nearly 1100 hrs on bf2 and I am still a few thousand points short of reaching that rank. Also cant belive how quick it takes the no skill having players to find exploits and stuff in these games
Battlefield Bad Company on 360, always up for a late session if anyone's around :(
360tag: Xion ink
^^^^ ditto.... lazy bast**ds
Steve
Edited by Noobs for Life
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
