  • Replies 838
Posted Images
Mercenaries 2 - PS3 (720P)
(been out since start of sept) - Got it yesterday, seems pretty damn good, the first mercs was a favourite of mine. In number 2 everytime you start a game it will host a server for you and your friends can join and you can do missions together, or you can join someone elses server.
Warhawk PS3 (1080i) - Best game on PS3 so far in my opinion.
online gameplay only. planes, tanks, RPG's everything you can ask for in a shooter. looks amazing on 1080 aswell.
Upgrades via the Playstation Network are great too, jetpacks dropships and troop carriers.
Still waiting on Fallout 3 to be released :P
My PS3 name is Stagezilla, add me to your buddies list.
Looking for more recruits in my Warhawk Clan - ACME Black Ops.
PS3: Battlefield Bad Company (I only play online) - I don't usually like fps games on consoles, but this rips it up! p.s. online name is Ry34
PC: Devil May Cry 4 - play this game with a wired/wireless xbox 360 controller for pc and you cant go wrong (its also very pretty)
TrackMania Nations Forever....bestest free game ever
werd...and Gloria or should I say Trish looks a lot hotter.
civilization revolution on PS3
not a bad game!! it hasnt really changed a whole lot.. last civ game i played was civilization3 on psone.. very similar!! but i guess thats half the beauty!!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
