sup
forgive the stupid question/noobness. but do rwc joints usually pick on such things?
i went today to about 7 places and they all gave me the same farkin answer "come by tomorrow or wednesday"
anyway, at one place the guy just took a very quick look at the car and spotted these 3 unroadworthy things.
going tomorrow to a...umm...a..."special" rwc place :P:) and get this over with but just curious...
bit tight don't you think?
dirty headlight
don't know if you can see it but the very thin line under the p-plate. bottom left corner of the p-plate (dirt)
dirt blinker
https://www.sau.com.au/forums/topic/155989-do-these-look-un-roadworthy-to-you/
as long as they work i dont see anything wrong.. If a windscreen is chipped or cracked its un roadworthy or moisture in headlights/tail lights
they all work. the line on the windscreen is just dirt that doesn't wanna come off too easily. whatever that is on the headlight, it's inside but it's just as good as the other one when light is actually turned on...
Those headlights are pretty bad and I have seen various EL Falcons, etc, fail roadworthy in similar or worse condition. As previously posted, try to use cutters and buff the headlights, but remove them off the car first and take care not to burn the plastic.
Windscreen can simply be polished off, by a professional glass polisher.
Tail light is tricky as you have a moisture issue, thus have a build up of dirt/grime inside the light assembly.
Think yourself lucky. Many years ago, to get a roadworthy, you HAD TO replace the windscreen. Without any form of measuring equipment, they always deemed that a (used) windscreen did not meet the standard for light transmission.
yeah i guess it's not all too bad but remember this was just a very quick look it wasn't an actual inspection.
i went this morning to a different place, didn't notice these little things but came up with this list:
l/h outer e/v boot split
r/h outer e/v boot split
radius arm bushes
he said it would cost $275 to replace these with new ones. does this sound right? already wasted $100 on the inspection.
still cheaper if i was to get a "special" rwc :kiss:
Edited by R-SPEC
what the hell is an EV boot.. a CV boot?
try ringing Chris @ Centreline for a 2nd quote 94692914. They're just off Mahoneys Rd and won't rip you off.
PS $100 is a ripoff.. I hope that was for 2 x $50 inspections at different places. Don't forget that if you take it back to the same place within the 30days you do not have to pay another inspection/RW fee.
how does that work? did they have to fix something or put in whiteline bushes? I think from memory their alignments are $90 for 4 wheel.
Edit: There you go, Michael said a camber kit is about $300 or thereabouts with an alignment.
Also it was probably a Whiteline kit, and Centreline usually charge less than if you buy direct from Whiteline.
You can have a look at one of Sydneykids threads to compare prices for the kits.
well being that I wasn't there and don't know the full circumstances of the problem, I can only suggest you look at the receipt and give Chris a call if you don't understand what was done to the car and what you were paying for. Chris has always justified what he has done or what needs to be done to our cars and the price/quote even without being asked and to the point of him giving me back the broken parts without asking for them.
To me it sounds like something else was obviously fixed/replaced and Justin isn't clear on what he was paying for.
hehe
nah dezz was with me at the time cause he got some work done on his car earlier that day.
aparantly... the camber on both wheels on the passenger side magicaly changed cause i had a big side on accident.. evan though theres no damage on my car... or on the wheels.. anyways
he goes "its going to take 2-3 hours to fix and cost a few $100"
and 30 minutes later the camber had the correct settings again.. and i was down $300
he evan said to dezz "your friend must of had a big accident"..
my theory is... 2 ppl installed all the suspension stuff originaly.. 1 on each side...
the guy who did it on the passenger side didnt do the camber properly or something...
radius arm bushes
still cheaper if i was to get a "special" rwc :ninja:
:rofl:
Agreed.......
Sorry Justin, i still find your story hard to beleive. I've been to Centreline, many times for different things, Chris is currently sorting out a set of coil-overs for my car, and i have had nothing but top class work at good prices.
It's strange how almost every person that works on your car f**ks it up or rips you off :) ; even though many others have never had issues using the same business.
If you still have concerns/issues, (and you obiously do) why not approach Chris and ask for clarification on what was done in those 30mins :huh:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
