Guys heres the reply instead of linking back:-
"ok, pics will follow when i have time, permanent fix requires:
removal of glove box. there you can see the plastic backing of the dashboard. drill a small hole in the middle behind the bubble dont go through the front! and 2 smaller ones at each end of the buble.
use some expanding foam to fill the middle hole and continue until it comes out both lttle holes. clamp and leave overnight.
superglue doesnt work as the foam backing of the dash absorbs it and goes hard, also liquid nails is too thick to spread inside the hole.
caution if you heat it slightly when you put the foam behind as mine started expanding outover until i clamped it lol.
mines all mupy now due to the superglue but its now stuck in place with the foam and if i had done that first i would be more than happy lol.
will get pics up soon. "
I'll be trying this later in the week with before and after photos for everyones inspection :P
did you get a chance to try this, any pics?
  • 1 month later...
I can confirm that expanding foam works well. The bubble holds good, only thing is you will need something in the shape of the dash clamped against it.
Other wise it turns out a little shotty, i did mine, but going to redo it again.
Either that or mount some guages over the top of it to hide the bubbles.
TOne.
used the heat gun today. seems to be holding for the time being. i'm scared of drilling holes in my car but i guess it'll come down to it if the bubble pops back up. pretty stoked for the moment tho cuz that bubble has been shitting me since i bought the car.
  • 3 years later...
I know that I am resurrecting an old post here, but has anyone had any long term success with fixing their dash/removing bubbles??
Has anyone had a professional remove the bubbles?? If so, how long did it take, rough price etc??
  • 1 month later...
what bubble are you guys talking about...
I see some varicose vein like things on my dash but that's it..
It's a bubble(s) that forms when the top layer of meterial covering the dash lifts off... Most likely caused by heat and moisture, It's not a factory feature ;)
  • 1 month later...
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
