They do custom? Are they anygood? I thought kmac did dodgy shit that VN owners bought?
Well with a heating torch & a pipe bender you can be your very own custom sway bar manufacturer... Have a look at the current whiteline cattledog. You will see that there isn't alot of science in it.
for some reason i can't find extra heavy duty r32 gtst front sway bars on whiteline (somethnig >24mm) whats the story, cause they have extra heavy duty for r33s etc
anyone know which ones are interchangible? (i know r32 gtr and r32 gtst rears are)
Yeah Kmac do custom...i have them on mine....27 up front atm...and 20 at rear. But they f**ked up the oreder first time....took me 3 months to get the first set. and they were totally wrong, so i sent my original down with the set and they remade them, i still havent recieved my old ones back yet. As for performance, they seem to hold the car well, need a thicker back one i think, but shit house service, and an good bar, i havent used whiteline so i cant compare them.
Oh and i just got non adjustable swaybars too, they do, do some really good adjustable ones apparantly.
Whiteline can make the cars for you, just depends if they want to, in their catoluges they have up to 34 or something mm thick bars. 24mm is the biggest standard line they do though.
I'm looking at around 7/8" or 22mm? soild bar.... Idealy bigger but I need to talk to someone to confirm 1st. Do I just call kmac number on the site? or does someone have hook ups?
Just call the number on the site. I dealt with Kevin, i think he was the manager.
go talk to steve, at pedder maroochydore, he is in the process of getting a custom sway bar made for my bosses daughter's mustang. the one that came with it was broken apparently. so he mite be able to help ya in getting something customized. worth a shot.
Or PM sydney kid on here and ask him if he knows anybody who could maybe help ya since he does all the suspension stuff on here he mite have the contacts you are after.
Edited by 85URK
Steve can go f**k him self, for legal reasons I will not make mention of what happened over the internet, however he better think himself lucky I didn’t take the matter further.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
