Was speaking to a tuner last week regarding my car, and he suggested i remove the FMIC and replace it with a pipe straight from the turbo to the throttle body and have a water or methanol sprayer installed just before the throttle body that sprays in vapour to cool the air.
He said the actual device (sprayer) costs less than $50 to install and its far more efficient than a FMIC that has a pressure drop and is heated by the engine
Anybody tried this sort of setup at all?
To me it made sence sxcept for 1 thing, wouldn't spraying vapour into the air mean that the water will get inside ur engine and screw it up? He said that the water inside ur engine would be harmless, but im not sure about this.
  • Replies 55
No...it doesnt screw it up as it atomises as it enters the intake into the plenum. it cools the intake charge and the fuel also, drops the temps a fair whack so you can add more timing and boost without any dramas. Search for The Mafia + Boost Cooler for info on the setup he tried and alot of others also.
We use it on our race car with great success. Its water and methanol, i wouldnt take the intercooler away, leave it but add the injection on top, intercooler still does a descent job.
However, like anything it needs to be tuned.
I run water methanol injection.
ok here are a few tipes -
1. Find another tuner. THis guy has no idea.
2. A Decent Watermethanol kits is $800. There is no way you could get a kit for $50. What, a washer bottle pump and a few $2 hoses? SOunds like dead engine to me.
3. I run water methanol injection AND a Large FMIC. I spray the water methanol through the intercooler for more effect.
http://www.full-throttle.com.au/Engine/Boost%20Cooler.htm
it might be effective, even more effective on its own.. i can't answer that
but what i think is you've got to think practically here..
with a FMIC you bolt it up and walk away. every time you drive its always there doing its thing regardless of rpm or engine load
with a water/methanol injection, it has to be tuned to only come on at certain rpm/load. PLUS, you have to re-fill it all the time.
for me, practicallity and proven effectiveness of hte FMIC makes it the winner every day of the week
  • 3 weeks later...
http://www.snowperformance.net/products.php?p_cat=262
Buy direct and it may save you a few $$.
Thats if you can. :P
R33_racer, how do you go about tuning the water meth?
I've been reading a little and it appears you setup the afr's to 12.5:1, turn the water/meth inj. on and set that up to drop the afr by half a point. Then start pushing the ignition in to it.
Is that how yours is tuned?
Anyone know of kits around the $400 mark, I've only seen them for $600 and over. Seems a bit over priced for what they supply.
If you buy a cheap half assed kit, you will get a cheap half assed result.
$850 for a kit is not overpriced - Considering you get a Shureflow pump (worth over $300) wiring, 3 nozzles (these are top of the range nozzles) and a variable controller with inteligence built in. They creat a nice linear curve of pressure so that you aren't simply turning the pump on full at some pump making a dead spot visible.
They start at 0% pressure and work their way up to 100% depending on how youve adjusted it. Saves water and methanol too.
These kits also have a output for an addon called saftey injection. THis is hooked up to a solinoid, and is plumbed in around your boost controller so that if you run out of water, instead of your motor going bang, it opens your wastegate and runs minimum boost until you resolve the issue. It can also output to a haltek input which changes to less agressive maps...
Trust me, if you buy a $400 kit, you'll regret not spending that bit more.
Links to the kits?
Don't be lazy and read the thread?
Edited by The Mafia
Yeah, I've seen that site, it'll probably end up being the same price once you get it to your door step though.
Hmmmm wonder if you can use nitro fuel from rc cars in water injection...
you can use something similar that they sell. Not sure how bad of an effect it has on the motor though
Mafia... What do you think about buying from the US as it does appear cheaper?
The kits are the same brand etc. But do they contain the same gear?
They are a fraction cheaper, but they won't sell them to you because they don't like to undercut their australian dealers. I've tried it.
Trust me, best option is to grab one of Full throttle performance. Best $850 I ever spent. Oh, and you neer ever have to use octane booster again, and that saves quite a bit of money over time. I remember when I was buying drum after drum of toluene, that alone would have paid for a WM kit that would have been so much better.
Serious question Brett?
The concept of using water injection involves adding the fine mist to a hot intake charge, and the water absorbs the heat energy to convert to a gas (steam), thereby cooling the intake charge. More dense intake charge then allows tuning to make the power. Obviously there are benefits that adding a certain % methanol to the mix brings, but note people do not use 100% methanol. Water will accept/mix the alcohol but only to a certain extent.
I'm aware of some of the properties of nitromethane, but who in their right mind would try using that in a water injection setup? The risk of fire amongst other things is just a little high, and I'd be dubious how stable that commercial mixture is - ie. how fast would you have to use it once opened?
cheers
Dale
Edited by Dale FZ1
Cubes I think you'd find the AFR would become leaner due to the increased density of the cooler intake charge. Therefore you'd want to add fuel.
The slower burn rate should allow more advance to be wound in as you say.
According to the boost cooler forum the blokes there state it makes the afr read richer.
http://www.snowperformance.net/forum/viewtopic.php?t=569
You will want to set up your A/F ratio to around 12:1 without the methanol injection and stock timing.
Once that is set you enable the injection and A/F should richen up by 1/2 point for 50/50 mix. Then start to increase timing 2-3 deg at a time until there is no change in HP.
and..
http://www.snowperformance.net/forum/viewtopic.php?t=731
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
