kris - what does "mexican" mean?
i often debate the definition with my friends...
the definition i conjured up - was... mexican mean the wheels are "escaping the borders" or "escaping the guards"
do you know for definite?
  • Replies 508
*facepalm*
its cos mexicans have a reputation in the US for bodging shit together on a low budget that inevitably ends up looking like ass and functioning as well as a bag of dicks. Often in the quest for well fitting wheels guys will snap up something with "epic dish" for cheap with no regard for offset or clearance issues, and then proceed to rock it anyway because they've already sunk what little money they have into shitty wheels. Thus, this fitment is called mexican, because the owner is automatically assumed to be some broke ass who is trying ever so hard to jump on the fitment bandwagon, but failing hard at it.
Here endeth the lesson for the day.
This'll give you a better idea...although the pic makes the tyres look like balloons but they're not really that bad...
Kei-Office do a front and rear camber kit - they do an option of -4.5 and -3 on the rear, I think the -4.5 might be a little extreme for my needs lol
http://page4.auctions.yahoo.co.jp/jp/auction/d109780605
kris that looks freaking awesome?? I wouldn't camber the wheels in too much.. Werent you selling these tyres anyway? Stretch a skinnier tyre if there's on available for that size... A guard pump might sort it but i think that looks pretty damn sexy.
Some tyre shine would finisn it off... It's a great car to advertise your bidness :)
Kristian, roll those fender lips outwards and tuck that shit, or I'm gunna track you down and the sphincter of the universe slap you.
lol -3 camber and guard roll for the rear should be fine - the car is actually resting on the tyres in that pic :)
Front will need a pull but shouldn't give us too many headaches - you gotta make the car fit the wheels, not the other way around :D
*facepalm*
My explanation is more awesome.
  • 3 weeks later...
Damn all of you!!!
I find myself wanting one now :P
find a large cardboard box.
cut a hole in it.
put some gladwrap on the hole.
get in the box.
sit facing the hole.
this is you in a cube.
do this for an hour and then decide if you still want one.
I always feel like Fred Flintstone when driving these cars in Japan..
I used to right them off as cereal boxes on wheels until I had to drive one for a month.
Quirky car, surprisingly roomy car, and biggest surprise was they were pretty good on the snow and ice and to top it off, reasonably economical.
But they still look like box on wheels
Haven't read all the posts, so I'm sorry if this is a repeat...
The recall in July this year of 46,000 Cubes due to fuel leakage after a rear-ender.... > is it safe to say that all imports to Oz are clear of this fault?
Some tyre shine would finisn it off... It's a great car to advertise your bidness :(
Classic example of the phunky monkey school of "mexican" :)
The recall is for 2009/10 model cars "Nissan recalls 46,000 2009-10 Cube models over fuel system integrity". If you ever want to check for recalls on any model car use Dog and Lemon.
It is the RAWS responsibility to ensure all recalls have been carried out when it complies the car, you can check some cars with the manufacturer online looking if recall has been preformed.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
