Group Buy # 4 Arospeed Adjustable Cam Gears, By Popular Demand, By Popular Demand
  • Replies 136
hey would you be willing to send these to NZ if i can deposit the money in your account
no problems, but it will cost you more for freight.
1) DJRIFT *IN FOR A PAIR
2) quiksta *IN FOR 1 GEAR
3) MRO *IN FOR 1 GEAR
4) lil_jaymeeh *IN FOR A PAIR
5) jaqule *IN FOR A PAIR
6) grandmasterb *IN FOR A PAIR
7) AWDMAT *IN FOR A PAIR
8) Cubes *IN FOR A PAIR
9) kghl *IN FOR A PAIR
10) Devils_Advocate21 *IN FOR 1 GEAR
11) NYTSKY * IN FOR 1 GEAR
12) rob82 * IN FOR A PAIR
20 GEARS SO FAR = 10 PAIR
Edited by r33kid
Sorry guys im going to have to cancel my order,a friend of mine bought two for his GTST and only needed one for the exhaust side,so i got the other one.
Sorry
10) Nightcrawler *IN FOR 1 GEAR
11) rob82 * IN FOR A PAIR
WE NEED MORE PEOPLE TO GET THE BETTER PRICING
12) Midg3t * IN FOR 1 GEAR
Still got times guys, so put your orders in.
2) quiksta *IN FOR 1 GEAR OUT
8) Cubes *IN FOR A PAIR OUT
Pm'd you on the (bugger, can't remember.............a while back) dunno ifya got the message but I would like;
Could you put me down for an exhaust cam gear please? To suit RB26, [unquote] color no wuckkers.
Cheers GW :P
2) MRO *IN FOR 1 GEAR
3) lil_jaymeeh *IN FOR A PAIR
4) jaqule *IN FOR A PAIR
5) grandmasterb *IN FOR A PAIR
6) AWDMAT *IN FOR A PAIR
7) kghl *IN FOR A PAIR
8) Nightcrawler *IN FOR 1 GEAR
9) rob82 * IN FOR A PAIR
10) Midg3t * IN FOR 1 GEAR
11) 260tech * IN FOR 1 GEAR
