Hey guys,
I have to buy a new clutch for my R32 GTR and i stumbled into these on nengun.
There's one rated for 700ps, price isnt bad either Link to site - http://www.nengun.com/orc/709-series-twin-plate-clutch-700ps
Anyone used one before? Anyone got one?
Tell me your opinions :wave:
https://www.sau.com.au/forums/topic/157154-orc-twin-plates/
I've been running a 709D on my RB25 for about 2.5 years now. Light and very well made. Hooks up very well. I'm using a standard RB25 slave cylinder on mine and the pedal pressure feels similar to a standard clutch.
Really? Does that make it hard to drive at all? I find light pedals + harsh clutches are a bad combination personally.
https://www.sau.com.au/forums/topic/157154-orc-twin-plates/#findComment-2941264
  • 1 month later...
Can anyone help me?
I bought an ORC 709D Clutch, I already have an unknown twin plate in there.
so I have a shorter bearing carrier. I also have an aftermarket NSK bearing(That I had installed last year)
Will I need to buy a new bearing for this one. What do I need to look for in a bigger slave cylinder? part # please?
any info is welcome!
THANKS!
https://www.sau.com.au/forums/topic/157154-orc-twin-plates/#findComment-3022575
Nah the ORC/BLITZ clutches have a very pregressive pedal even though it is light, once the OS is shagged in ours it is getting the flick for anothe ORC/BLITZ twin.
https://www.sau.com.au/forums/topic/157154-orc-twin-plates/#findComment-3023970
  • 3 weeks later...
  • 1 month later...
thats because you need driving lessons marcus :rofl:
There really not that bad...i got a quad plate OS in mine and a freind of mine also has a quad plate in his supra and they work well.....If you rest your heel on the floor and hinge your ankle you can take off with no throttle at all....trying to use them without stalling or hopping by bending your knee is almost imposible.....its like trying to use a clutch lever on a motorbike by holding the lever with your fingers and pulling your shoulder back as apposed to using it the proper way by using your fingers to squeeze and release it....try it with hinging your ankle.....i think you will be suprised on how easy they are to use (unless you have a size 6 foot)
Edited by ylwgtr2
https://www.sau.com.au/forums/topic/157154-orc-twin-plates/#findComment-3165255
that is exactly what I said to marcus. i have been using os tripple in my GTR. basically I just adjusted the rod so the pick-up is not too far off the floor, then I can easily keep my heel on the floor and only lift it once the clutch is completely engaged. makes it much easier to feel the friction point. :laugh:
https://www.sau.com.au/forums/topic/157154-orc-twin-plates/#findComment-3165268
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
