Hi All,
Just wanted to know if anyone has tried (or looked into) the following;
In UK many nissan vehicles have factory installed navigation and info controller (350z / X-trail / Narara / etc) that is both a PAL system and in english.
If someone imported the nav / info controller from a UK car and plugged it into the 350GT loom (they all appear to have the same / similar wiring loom) what is the chances of it working ? (I know the NAV function prob wont work because its setup for UK software).
It also appears that the LCD panel may be both NTSC and PAL compatable as the UK and US part numbers for the LCD screens for a few nissan / infiniti vehicles are the same.
B.
Where do i go to get my Nav converted in Sydney?
Another thing i have the DVD Rom which is in the glove box, this displays DVD ROM ONLY, can i play japanese DVD's using this Rom as i borrowed one from someone???
Japlink car sales in Sydney will get your tv/dvd working for
$2k and for $2k more they will get your sat nav working.
I know if i were going to spend $4000 on my car it wouldn't be on a 6" tv screen.
Hi All,
B.
do you know what system they run? the screen inthe 350z is slightly different to that in the v35 and m35.
in these cars its a complete assembly that will come out in one piece.
looking into the US domestic piece myself - have family there that can do the legwork for me. that will fix the menus but not the nav/tv side of things.
T88,
nah, its a JDM only- why spend the extra money on that when it was never to ship (officially) outside japan.
anyone recon this may work here?
full dash
only need to find the AUS map cd??
a few problems there..
firstly, yes the unit will probably work if you want to fit the new DVD-rom and computer into your V35
BUT
1) there are no australia maps made by the company that makes the unit
2) it will display everything in "infiniti" instead of nissan
3) not sure if all the features (eg avg fuel consumption) are the same with the G35
as above.
fuel cons will be in standard not metric.
its the EXACT unit I have here in front of me so no go on the nav side of things.
does half fix the radio issue.
What about the Nissan Murano system? Same engine, platform, Bose system etc. Have scene the navigation and the screen appears to be the only item that is differently setup (ie not pop up (I am sure the two could be matted together)). Should plug straight into the loom and run everything we need along with the navigation and Australian maps.
yet to prove that. though the units are not etirely the same and I seriously doubt any of you wish to spend $3k on the box to find out :)
I'm working on a few things I'll explain once I'm done.
Australia Murano used the VOD system, it is no way to cross use map or software.
Thanks Frank, well aware of the Murano’s use of the VDO system. I was not talking about the software, but purchasing the complete navigation unit as fitted to the Murano. Unplug and discard the original V35 box, retain the screen and plug it all into the Murano running gear. If it can be confirmed then I am there. I am aware there would be pain in getting there, but it may tick all the boxes.
Someone needs to get an extended test drive of a Murano and give it to Chris Rogers for several hours. Maybe just maybe it will work. Here’s trying anyway.
Yes that is the only way acceptable. Unless we can sourse a cheap 2nd VDO unit, that going to cost us 1500-1700 which I think does't worth at all.
On the other hand as I know, a lot of VOD system only has a RCA out put by the V35 screen only has RGB input. That mean a conversion box may needed.
Or may be we can used the TV box wire which I don't know what standard it is?
Edited by Frank350GT
This is the connection board on the pop up screen. TV connects to the TV+ pin and I think the RGB pins connect to the Sat Nav unit. I couldn't get it working with 50Hz NTSC so it needs a proper 60Hz NTSC modulated signal.
tom,
great idea, poor execution. the later ones run CAN and pulling that board WILL SHUT THE CAR DOWN. tapping the wrong wire will kill something or a CAN module.
the TV tuner is simple cracking that module open is another matter.
Hi guys,
T88Turbo, did you get a Japanese DVD - did it work?
Chris, you wrote "if it says DVD video ont he face of the unit then it supports it." Where abouts on the head unit would this be written? Do you have any pics?
Thanks, Ben.
Guy's be very careful when stuffing around with the NAV/Stereo System as it has cost some people a lot of money when they did some serious damage, it has affected other things by accident including ABS and AIR BAG's with codes going off for even over a week after putting the system back together.
A complete plug and play system is being developed base model and high end (not by me incase you asked) as after 2 years their is no easy way to get them working, stereos are not covered under warranty if you bought it from a dealer then short it out after taking the NAV system out.
Has anyone ordered the buttons in English from the US so at least the Japanese symbols are gone.
Hmmm I was going to but the buttons are different to the JDM ones as the US ones don't have the TV unit and there fore the buttons dont match up.
CopyofDSC01367.jpg.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
