on par. GPS wise.blau lacks the 3d mapping but the blau has a AV in that can be used for a multitude of things that the garmin/kenwood does not . it also supports a reverse camera as well.
hmm interesting.. i was a bit disappointed that the blaupunkt did not do 3d mapping as i mentioned via PM. i've gotten used to that style on my PDA version tomtom..
how do they compare cost wise, and in temrs of installation? easy for you to get your hands on chris?
this website has an instaleld setup and it seems pretty good: http://www.nsxprime.com/forums/archive/ind...hp/t-74166.html
i know you've already got the blaupunkt unit there, but i'm just thinking in terms of my setup as i've already got the reverse camera, and i don't need the extra AV inputs as i've already got the TV/DVD potentially sorted through the TV tuner AV input..
https://buy.garmin.com/shop/shop.do?cID=134&pID=10573
seems there's a GVN53 out now too..
doesn't look that different though from the spec sheet, only advantage over GVN52 seems to be XM and traffic stuff
Edited by WazR32GTSt
Hey guys, i got this reply from Ryda.com.au if its any help tp any one.
Hi Angelo
Most factory vehicles have there own factory design plugs and configuration, most aftermarket brands like Kenwood you can only use there head units to run there own GPS Nav units.
There is a brand that has a regular RCA Video out from the GPS Nav to plug into a unit with RCA Video. The GPS Brand is a Nesa model NAV-12 unit with remote control and GPS antenna that has 2D 3D and birds eye viewing Normally priced at $999.00 our price is $699.00 plus freight if need of $17.95.
Now probably the original screen has no RCA video out so this wont work, if the unit can be taken out and taken to aftermarket electronics wiz he could ad an Video out of you would need to check first if they will do this there is one Company that does this to BMW Mercedes and others he is based in Sydney and the name is Nam Electronic Services in Marrickville Sydney PH: 0295504144 in the name of Nam Nguyen you could ask him if its possible.
The first question is the aux input is this just audio which is a good start all we need is a RCA video input feed out as well.
Thank you in your enquiry hope our info was helpful.
Regards,
Dennis Beroukas
Ryda Dot Com
T:0295688852
F:0295683522
email:[email protected]
wycky,
the aftermarket "black box" or "hideaway" type of units (such as we are looking at here) are all designed to be used with and OEM screen. that was the reason for their inception in the first place.
this includes units from garmin, blaupunkt, vdo, etc
its just a matter of finding the one that has the interface and mapping that you like
in regards to the factory aux inputs, well there is video, audio L and audio R so its completely normal in that regards if you want to plug it into the aux input
if you want to wait for chris to finish developing his plug+play then you will find that you can plug it into the stock nav loom so that it is activated like the normal nav and your aux input is free for a dvd/tv etc
this won't be too far away now..
the nesa version was one I originally looked at. it does RGB out. I have the pinning or it here and it was the original cable I had built O/s. nice to see ryda doing the right thing :P on price.
mapping on it is 3d like the garmin unit. the garmin has one advantage over it. the STOCK GPS antenna is a plug in affair. the rest is not but in my case thats not an issue.
Waz,
remember the pearl 35 I had a few days back - its staying here a few more days :) so I'm going to strip it and make more notes :D
I'm making a call to garmin now btw.
Does anyone know if the same goes with the 350z?
A friend of mine just bought a personaly imported 350 with sat nav and is wondering how to get the unit to work here in australia.
He is willing to go aftermarket but would just like to explore this option before doing so.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
