I'm getting my parents banged up VL commodore to drive while my car gets its manual conversion. What are some fun cheap mods to do to a VL auto I can play with while I have it. This car is stock as a rock, nothing has ever been upgraded on it.
Shoot me some ideas, even stupid ones.
https://www.sau.com.au/forums/topic/157610-im-getting-a-vl-to-drive/
advance the timing to 21deg and run premium :0 remove the air filter. go to BOC gasses and buy a 10kg bottle of nitrous, 3metre braided stainless hose and a slow release needle valve set to 1bar! veed the hose into the airbox :) hehe!
I had a mate in sydney with a ghetto nitrous setup on an old falcon same as above. he would stall it up and on launch and open the valve and instant tyre smoke
Nedless to say you will put a rod thru the block if you are not careful
I would cut the springs, spray it mat black and get at least 7 mates in it and drive around Braddon with smoke pouring out the windows and a crap sound system turned up too loud, Then when you get pulled over by the cops you too can ask.....
"Why are they picking on us?? What did we do???"
Seriously, hard springs and weld the diff... for some scary dori :(
Is it a VL Turbo? If it's a turbo, put a HKS pod on it, great flutter!!
If it's anything else, well, don't let anyone see you driving it I guess.
If it was a VL turbo I would have said that. It's a standard executive that still has the original hub caps it came with. My Grandparents had it since new in Canberra, then gave it to my Dad in Bathurst for nothing about 7 years ago. It's been a pizza delivery car for a few years, so it runs like crap and stinks.
I was thinking about suspension upgrade/repair and then a full-sik bodykit made out of cardboard for a g-up. It's not even worth the cost of the rego to keep it on the road, so I might paddock bash it to death or something when I'm finished with it.
What is a well deserving end to a reliable old VL?
VL getting a hard time in this thread!!.......I owned a VL for many years prior to the R33 and it served me very well.
Dont get me wrong though id never give up the skyline for one :D
Cheapest mods i mucked around with were advancing timing + timing belt check out:
http://www.calaisturbo.com.au/showthread.p...=advance+timing
www.calaisturbo.com.au is a good general site for VL and RB30.
Terminal
I think i have a heap of wheels, parts, gearbox, etc to suit at my folks place (if they havent all been dumped)... they are of no use to me let me know if interested and ill have a look.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
