I'm getting my parents banged up VL commodore to drive while my car gets its manual conversion. What are some fun cheap mods to do to a VL auto I can play with while I have it. This car is stock as a rock, nothing has ever been upgraded on it.
Shoot me some ideas, even stupid ones.
https://www.sau.com.au/forums/topic/157610-im-getting-a-vl-to-drive/
advance the timing to 21deg and run premium :0 remove the air filter. go to BOC gasses and buy a 10kg bottle of nitrous, 3metre braided stainless hose and a slow release needle valve set to 1bar! veed the hose into the airbox :) hehe!
I had a mate in sydney with a ghetto nitrous setup on an old falcon same as above. he would stall it up and on launch and open the valve and instant tyre smoke
Nedless to say you will put a rod thru the block if you are not careful
I would cut the springs, spray it mat black and get at least 7 mates in it and drive around Braddon with smoke pouring out the windows and a crap sound system turned up too loud, Then when you get pulled over by the cops you too can ask.....
"Why are they picking on us?? What did we do???"
Seriously, hard springs and weld the diff... for some scary dori :(
Is it a VL Turbo? If it's a turbo, put a HKS pod on it, great flutter!!
If it's anything else, well, don't let anyone see you driving it I guess.
If it was a VL turbo I would have said that. It's a standard executive that still has the original hub caps it came with. My Grandparents had it since new in Canberra, then gave it to my Dad in Bathurst for nothing about 7 years ago. It's been a pizza delivery car for a few years, so it runs like crap and stinks.
I was thinking about suspension upgrade/repair and then a full-sik bodykit made out of cardboard for a g-up. It's not even worth the cost of the rego to keep it on the road, so I might paddock bash it to death or something when I'm finished with it.
What is a well deserving end to a reliable old VL?
VL getting a hard time in this thread!!.......I owned a VL for many years prior to the R33 and it served me very well.
Dont get me wrong though id never give up the skyline for one :D
Cheapest mods i mucked around with were advancing timing + timing belt check out:
http://www.calaisturbo.com.au/showthread.p...=advance+timing
www.calaisturbo.com.au is a good general site for VL and RB30.
Terminal
I think i have a heap of wheels, parts, gearbox, etc to suit at my folks place (if they havent all been dumped)... they are of no use to me let me know if interested and ill have a look.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
