Gday,
I'm going to attempt to build an exhaust for my r31.
Questions:
1.)
Is it better to get straight pipe and do crab bends like the J style intercooler pipes or go to liverpool exhaust or somewhere and buy some bends?
As far as I can see the crab might be cheaper and harder to mess up the bends, but take longer (I don't have a band saw, it'd be done with an angle grinder). Also to sand down the weld marks on the inside might make it weaker?
2.)
How do you join pipes? Last time I did it I hammered one edge out a little so it would fit over the other part of pipe. Obviously so the bigger one went into the smaller from front to back so the exhaust gasses wouldn't be slowed down too much.
Having said that is it better to just have them together without overlap?
3.)
How do you weld hangers onto the pipe? I would assume it'd be best only to weld them to flanges, otherwise I'd probably make a hole in the pipe.
4.)
What thickness/grade of pipe should I be using? Is there anything I should know about purchasing the right piping? I know I can just walk into the zorst shop but thought I'd ask.
5.)
Anyone have tips on design technique? I was going to take the old zorst out and copy it, checking each section as I went on the car. I'd purchase a normal single down/front pipe, then weld a flange to a bit of pipe, attach it take it off, copy the old etc etc etc etc. Anyone have any tips?
I think that's it. Thank you.
PS great section :laugh:
https://www.sau.com.au/forums/topic/158226-building-an-exhaust/
1) there are usually only about 4 bends in the exhaust, so at $20 a bend for stainless you would be better to use them instead of the section bends, considering the time it would take, as well as the limited accuracy you would have with an angle grinder. If with stainless you would want only a gap between the pieces that is smaller than the filler wire you will be using. you can do it, but the trouble with increase and neatness will definately be affected.
if you decide the crab style, then use 7 degree's of less for the angle of the cuts - any more and the matching of the end pieces becomes ugly,hard to weld, and a flow restriction
2) butt joints will be best, once again its neater, but true it would be harder to weld neatly but would look better in the long run and no worry of affecting the flow
3) most hangers are welded onto the side of the exhaust where needed, just ensure there is no burn through or holes. as well and sufficient area of weld to prevent any cracking since this is where the weight is taken from. also from what i have seen, try and triangulate the support so there is more coverage
4) up to you on what you want to pay for the grade of stainless, just remember to match the filler with the grade of steel you use.
5) it would be easier if you did it in sections, but it really depends on why you are changing it in the first place. If your happy with the design and it seems to flow well, then i would copy it.
tom,
don't even try lobster. just buy bends :happy: take your exhaust off and note what bends there are and buy the same in steel. liverpool exhaust are really cheap.
also ins't your welder a arc welder?
yea i did this with my r31, mine was very low so i ran the 3 inch under the diff, so yea with any normal 31 its up and over the diff which will be a pain in the arse with straight pipe cut and shut into bends. I made mine out straight pipe. if i was to do it again i would have bought bends. did the job well tho.
Thanks for the comments guys.
The exhaust will be mild steel. I don't really care for stainless - it's a r31 so if it gets the job done well the cheaper the better.
Ok, so the section bends are out.
What's a butt join?
r31's have crap exhaust path, have to go over the diff. I couldn't go under my car would be illegal and I'd wear it through scratching it. I don't like th idea of it flowing up and over (it's a fair looking restriction) but what can you do other than get a s13/a31/r32....
Nic, no idea. It's Jacek's. I'll just try to use it, it seemed to work last time <shrug>
What's a butt join?
butt joint, there are different types, but have a look in the welding 101 thread here http://www.skylinesaustralia.com/forums/in...howtopic=156412
the post by JAS-25T has a few PDF's one of the the TAFE one, has an outline of different butt joints.
For all my exhaust I just buy a few 90* bends and a length of straight tube.
Exhaust for an RB20 into a BMW
Exhaust for my Hilux
mate i did all mine at home on the floor 3"mandrell bent pice of piss if you want a look at it send me a pm or phone me or ill doo it for you exhaust that is ! ph 040902772three
  • 1 month later...
Got a question for all you tech heads out there.
Does anyone have any pics or diagram of a 1 into twin pipe setup? I've got the pipe and want to fab but unsure of how to get 1 pipe into twin pipes.. they are all the same diameters. I've sat with a bit of plastic pipe to try to get the angles but I can't seem to do it! :\
  • 1 month later...
You can buy 2-1 collectors.
Or notch to match and weld it up you self. Hard to explain, you just got to sit down and try it.
i've tried to think of ways to make the Y collectors but even after looking at pics of one like below, still a bit hard to work out the angle and cut needed to bring them together and get the single pipe to match perfect.
doesnt look like it would be too hard to make one up (says me who probly couldnt lol)
all you have to do is cut it from the very middle of the pipe up along the length of it, and any angle towards the side really, as long as its even on both sides if you get what i mean? thats for collectors with the same size pipe joining it eg: 3 inch pipes into 3 inch collector
  • 10 months later...
bLaQ.bOi got it spot on you do need purge that is if your using stainless, If you think you can control this with the amount of penertration that just means your not getting a full strength weld.
As for the collectors use the link above, and to get the right dia multiplie the dia by pi eg: 3" = 76.2 mm
so that 76.2 x 3.141 (3.141592654) =239.3893602 after getting this simply measure out that lenght on something to wrap around the 2 into 1 joint and cut, use a flairing tool or pressing tool to bring it to a nice round shape and bam thats it! happy fabin :bomb_ie:
  • 4 months later...
when i get some time i want to modify my exhaust by putting in a dummy muffler with a hidden bypass as close to the front of the exhaust system.
i want to do it in a dummy muffler because bypass valves are illegal in perth and i want to hide it.
can any body see a problem with this?
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
