im in the same position as most of you with pushing the injectors to their limits but for now im just winding the boost down 1 psi and wait for the 600cc injectors and f/pump when i get some more cash then = high psi :D
  • Replies 45
Posted Images
I'd do what your tuner is comfortable with doing. Heaps of people on the forums have made substantially more power than 225 rwkw on stock fuel injectors with a bit more rail pressure.
There's no problem bumping the rail pressure up a bit etc (it is suspected that s15s run higher pressure) than our cars. That's why the injectors flow 440 cc on r33s, but 480 on s15s.
I just wouldn't go running a million psi that's all.
  • 5 months later...
I am making 270 rwkw with stock injectors and stock fuel pressure (and reg.) with no knock issues at all.
I do have very bad fuel economy though, could the stock injectors be contributing to this at all?
Cheers
that's a fine theory except that 33 GTST don't have anywhere even near 440cc let alone 480cc injectors. they are 370cc...
This is not possible unless your fuel pressure reg is busted allowing huge line pressure or you have aftermarket injectors and don't know about it or the dyno setttings have been tweaked :(
Stock injectors and same figures on two different dynos (one being the PAC racing dyno)...
FPR may be busted? Would this be giving me bad fuel economy?
You guys can all laugh, but there IS a definite relationship.
Basically 6cc per minute per flywheel horsepower is a very close approximation of fuel flow at optimum air fuel ratio.
As you have six cylinders, and six injectors, that means max flywheel horsepower = Injector flow at 100 percent duty cycle.
So basically 550cc injectors would equal 550 flywheel horsepower absolutely flat out at full maximum duty cycle. But that is not real smart. You might want to limit it to 80% duty cycle maybe ? Which would be only 440 flywheel Hp.
But then there are drive train losses, typically only 85% of flywheel power makes it to the rear, so that comes to 374 Hp. Converted to Kw that is 275 RWKw.
Depending on the injectors you run, and assuming the fuel pump is up to the job you CAN figure out a reasonable RWKw versus injector size.
So absolutely balls to the wall with no margin might be injector size in cc x 0.85 x 0.746 = RWKw
Something safer and more reasonable might be injector size in cc x 0.8 x 0.85 x 0.746 = RWKw
yes, but that's a relationship between injector size and horsepower, not injector duty cycle and horsepower. duty cycle doesn't tell you anything except for how long in 1 cycle the injector is open for. I can have an injector duty cycle of 80% by I'll be getting very different amounts of fuel between a 300cc injector and an 800cc injector...
Cheers
HAHHAHAHA what dyno....... i want to put mine on and im sure it will run 500rwkw if you ran 270rwkw.
I told you what dyno. PAC racings dynapack hub dyno and also a dynodynamics roller dyno. Have you heard of the PAC boys before?
Well done if you have 500 rwkw, nice power.. I know its making 270rwkw, I am sure that the three tuners and two dynos I have used would not be out.
What ecu are you running?
Those out there who have fiddled with batch injection. Is it possible to get close to that figure with batch fire?
i.e 2 injector pulses per cycle vs the 1 pulse (sequential) the std ecu and pfc uses.
(remembers back to the 533rwhp on stock injectors thread) :huh:
(remembers back to the 533rwhp on stock injectors thread) >_<
just the PFC. I have many people that can verify that its making the power I said and I know that injectors and FPR are standard, only fuel upgrade has been a bigger fuel pump.
ok.
Well as you can understand its definitely not possible to run such figures with stock fuel pressure and injectors.
Have a look at the std fpr and tell me if it looks as if some one has smacked its top in a tad. Its a crude method of upping fuel pressure.
Whats your tuner think is going on? He would obviously have some idea as the base map would be way off the mark if it were running higher fuel pressure and or highflowed injectors.
Bet you have a blockage in the return line and or the pump they are using is massive ie too much flow for the standard reg to flow so you have higher pressure at lower duty cycles as the fuel is not being consumed. This would explain both the shite economy and the large power figure.
*DISCLAIMER*
The below is a loose quote of a conversation between a well-known "old school" Brisbane tuner & myself not long after I bought my GTR. I myself have not confirmed what he said to me & will therefore recommend you do your own research BEFORE attempting this at home.
This guy was involved with the build of my engine & was adamant that std Nissan injectors were considerably under-rated from the factory & I should have no problems flowing enough fuel to create 600bhp considering the hardware already attached. What rail pressure was required to do this was not discussed, but it would have to be a fair chunk higher than std which in itself is not really a good idea. Under bonnet fires fed by leaking fuel delivery systems get real nasty REAL fast......
I do intend to actually test the flow-rates of assorted std injectors vs rail pressure simply to answer the Q of whether this is in fact attainable but only in a test rig & even if it is doable, bigger injectors & lower psi is always going to be safer than smaller injectors & huge psi.
Food for thought.........
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
