OK for all you budding or wannabe mechanics see if you have any ideas on this one..... even if they seem obvious im open to any suggestions!!!!
My car doesn’t idle properly
It hunts when stationary and sometimes goes close to or actually does stall when you lift off the throttle. The faster you lift off and the slower you are going the worse this is.
Its running rich
At the moment it is going through a full tank in 200km as apposed to the usual but not much better 350ish. This seems to be only intermittent though as sometimes you cant see any black smoke and other times there is heaps. By heaps I mean more than the usual skyline running rich on boost from factory.
It is not boosting up properly
It usually has positive boost by about 2500rpm but at the moment its not getting positive boost till more like 3000rpm to 3500rpm. It sounds like the turbo wastegate is opening early and bleeding off boost to early as you can hear the turbo spool up but nothing happens until later in the rev range.
It is down on power all through the rev range
Im sure this is quite obviously linked to the turbo problems.
I have reset the ecu but this had no effect on any of the above problems.
I have also had the air flow meter cleaned,the compression checked and im sure a few other things checked that i forget.
As far as mods go it has a turbo back exhaust, pod filter, front mount although still running standard boost as the next step was to wind the wick up a little but that seeems kinda stupid at the moment given the way its running. factory computer, no boost controller.
Any help would be much appreciated ;)
https://www.sau.com.au/forums/topic/158333-who-wants-to-play-detective/
Its running rich
check/ change the air flow meter first oops didnt see that u typed it but it could be
Edited by R33GOD
intercooler pipework leak
causing some pressure in the manifold to be lost to the atmosphere, gives it a bit of a laggy feeling. its stalling or struggling as some pressure and air is leaking out, so its over rich.
the bad economy could be the same problem or it could be your 02 sensor is shagged. the die and only last about 50,000 k's so chances are you have never changed it, so do that and it should fix your economy.
Thanks for the heads up guys im open to more suggestions as this one's got me stumped. We did clean the air flow meter. but haven't checked the 02 sensor.... Excuse my ignorance but were abouts is this? do you mean the one in the exhaust???? or is there another in the manifold or something???
yeah the 02 sensor is in the exhaust dump pipe
3 wire sensor
its used for fuel economy and correcting rich mixture
Yeah thats one of the on the list of things to try that we havent got to yet!!!
Thanks paul
Anyone else got any ideas?????
Try swapping computers maybe???? By this i mean to another stock one.
Check your IC pipes again - thats your problem.
Thanks for your 2cents... will check em again tomorrow but we did go over all the joins with soapy water to get some bubbles showing to no avail...... Its starting to s%#t me though so ill try anything!!!!
it wont be the ecu
it doesnt wear out or forget
Yeah just heard a few stories of older cars getting electrical gremlins!!! After all the old 89 r32's aint spring chickens no more!!!!
Thought i would be a waste of time im just trying to think of everything. Funnyly enough me not being a mechanic means the most logical explinations dont always come to my mind first!!!!
thanks again for the input guys!
A classic sign of a faulty O2 sensor is hunting when the car is idling. Judging by your poor fuel economy this would also support a faulty sensor. To test if it is the O2 sensor, simply disconnect the O2 sensor next time the car hunts and see if the idle stabilises.
Hope this helps
Hope this helps
Thanks again guys!
Will be checking all these options tomorrow hopefully. Ill post if anyone wins with their diagnosis.....
keep anymore ideas coming though however stupid!!!!
My money is on a leaking BOV. I bet you have an ATMO bov and it is leaking :happy:
Ha ha... good thought but i dare not partake in such foolishness when the factory one is more than capable and one less thing to get deffected for, also they make enough noise standard i and my car is loud enough as it is!!!
There could be a problem with the the temp sensor f%^ked and then the ecu thinks that it needs to go on to cold start enrichment!!!
It will kill the fuel econ and when hot it will be to rich and be flooding!!
Just a nother place to look.
Thanks again for the idea but i think we can rule that one out as it seems to run the cold start up mode ok and it idles fine in this mode, all be it at about 1100rpm. Then settles down to its hunting on idle shennanigans after the car has warmed up so i think the cold start must be off after that..... Good idea though and one i'll investigate further if the others come up with no results!!!!
:wub:
:happy:
Engine will start and run fine from cold because that is what the sensor is telling the ECU. However, if the sensor is shagged, it continues to tell the ECU that the engine is cold, despite the fact that the engine is actually up to temperature. When the engine is hot, it doesn't run so well when the ECU is dumping sufficient fuel to keep a cold engine running.
It's certainly worthy of consideration in your quest for a resolution to the problem.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
