All S14s have variable cam timing as well as the points i mentioned earlier. How do I know? Because I own both. :ninja::laugh:
ya what he said.
r32 i think... but i come down to the launch and gear changes.. so on
obviousssssly.. but wouldn't it be fair to compare it like for like? ya i think so!
  • Replies 50
OK, here is my 2 cents...
First of all, it would really depend on the drive as it's straight down the centre line 400 metres...
secondly, the S14 Silvia will win not because it's more powerful, but because it's much lighter.... it will win by half a car length! not much, but enough to win... it's power to weight rations baby!
But the Skyline looks better, drives better and is more powefull.... noone can dispute this! AM I RIGHT FELLAS?
well actually the s14 is more powerful. 164kw for the s14, 158kw for the r32. it will win because it is both lighter and more powerful.
who really cares in the end it would only be a car length or two, a decent driver would be more important then power or weight
Edited by thorpe84
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
