Hey fellas, I've got an issue with a hks 2535 which i have just installed on my R32 gtst...everything seems to be in order with no leaks in lines or piping but there seems to be an issue with the boost...it is EXTREMELY laggy and only starts to create positive boost above 3500rpm...which is late even for a rb20...then theres the main problem...after about 5500rpm or so...the boost just skyrockets uncontrollably and doesn't stop rising...i've accidentally hit 1.2 bar on it...the turbo has an adjustable wastegate actuator by the way...can someone shed some light on this please?
https://www.sau.com.au/forums/topic/159128-hks-2535-and-skyrocketing-boost/
check that the actuator is opening all the way... if it is then make sure the wastegate hole on the back of the turbo is big enough to let the gasses escape... the problem here is that your exh gasses arn't escaping in effect creating more boost.. theres a few threads that people have put up with the same problem just have a look around..
also check that your cat isn't blocked
hope this helps :laugh:
Haven't left any of your original vacuum tubes unblocked?
I'd check your tubing setup too to be sure.
I installed my turbo (2535) yesterday with the most basic setup..... just the one tube going from the pressure source (nipple off the intake piping) straight to the actuator.
No boost controller at all yet but will soon.
Where are you dude?
If not too far away we can compare setups.
Working in North Sydney today
3.5 sounds about right to me my 2530 wasnt coming on much earlier than that
and wind the Actuator out to lower the boost alittle anything under .85 though and you'll get worse boost response
as hks actuators are meant to run on .85 bar
why are you worried about hitting 1.2bar, thats where my 25/30 sits at on RB25.
As for skyrocketing pretty normal buddy thats where your car is making peak torque and power, as for coming on a bit late well rb20 with that size HKS unit mmmmm. Get it Dynoed.
nah i think thats about right.. my 2535 on my rb25 starts at about 3000 and realy starts moving by like 35-3700rpm
if you disconnect the wastegate and give her a test real carefuly i think that will show you the fastest it'll boost up so u can compare.. careful thogh cause it'll run at unlimited boost
3500 seems alittle late to me for it to make positive boost but i'll have a look at the rest of the engine again...please keep the suggestions coming fellas...cheers...
I'm definitely not worried about running 1.2-1.3 bar on that turbo as i plan to do that in the future...i'm worried about it now though because my injectors and afm will be maxed out way before that...i have a remap and the car is tuned to only 165rwkw at the moment...with air fuel mixtures spot on...so if the 2535 is running 1.2 bar...i will defninitely be running lean...and thats even before ignition timing is addressed...so thats why...there no point in dynoing it now as i have yet to get the injectors and z32 on yet...and by skyrocketing i mean it doesn't go to 1.2 and sit there...it keeps going and thats why i got worried...
If it keeps going up and up its becasue the exh gasses are not escaping quick enough... start to point the finger at the wastegate, boost controller, turbo and cat.. think about everything that your car needs to let the exhaust gasses escape... if it don't let them escape it wont hold boost.. it'll just keep rising..
i had the same problem and mine turned out to be the wastegate hole on the exh housing of the turbo that needed to be ported out... the hks actuator should only be a 1 bar actuator or less so something is wrong... even try just connecting the vac line from the inlet manifold straight to the wastegate and see how much boost you make.. or the other alternative is to go on the dyno... save you alot of headaches and if it gets dangerously lean they stop the run.. on the road its hard to tell
Thanks mate...that kinda suspected that might be the reason...i'll have to pull it off and have a look...cheers...
dont worry man im in the same situation too, it just keeps on spiking, im thinkn just gettin a stock actuator, not this adjustable crap,and just running a boost controller
let me know if u find a solution and if i got one i'll let u know, coz its annoying the hell outa me
do u have a boost controller connected up?
if so, take it off and connect the hose directly from the compressor housing to the actuator.
My HKS GT2535 does the same on the RB20det with R32 actuator. It goes 11psi roughly and then creeps to around 15psi with no boost controller.
I thought the acuator was stuffed so tried a RB25det one. 7.5 psi and then creeps up around 12 or something LOL. The turbo is coming off soon so i might grind the f**k out on the waste gate area.
You would think HKS found and rectified this problem, c**ts they are.
my personal opinion is that if you can afford a HKS 2535 and the required supporting mods, then you can also afford poncams + adjustable cam gears to make it come onto boost a lot earlier. i wouldn't be surprised if you could get it down 500-800rpm based on my own personal experiences
Thats the way they work!! You put a bigger turbo on, you get more lag, more power, more lag, nothing in the world will stop this from happening!! Cams will give you better mid range and bring boost on a little earlier but not by much.
My RB20 runs a HKS2530 and it behaves exactly how it should, boost is on by 4000rpm and rises to 18-20psi.
Goes like a dream. Maybe you were expecting something else. I have never seen a big power turbo make boost below 1000rpm, that is total crap!!!
The HKS internal wastegates are second to none. If you think you can improve on them good luck!!
You must run a boost controller on these turbos and they need to be dyno tuned. Bleed valve is only $50. Come on now and get serious, I cannot believe some of the rubbish that is posted..
Gee...thanks for the technical lesson...i'm a certified mechanic and mechanical engineer and been involved with turbo cars for 4 years...as if i didn't know that a bigger turbo would cause more lag...when i said positive boost at 3500 (NOT 1000rpm) i meant that the boost gauge would read 0.0bar at 3500 or more...now that i know for a fact is abit late...i'm asking for opinions and suggestions here...i don't need to know that i need a boost controller and i need a dyno tune...so before you try to teach me how about you read your own crap first...i don't NEED to run a boost controller if i don't want to...if you say the hks actuators are second to none then they will hold whatever boost level they're meant to hold properly...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
